Hey guys!
Just wanting to know how much boost i can run and what sort of rear wheel kw's i can expect at a few different boost settings (eg 1bar and 1.2bar)
Car:
R32 GTSt RB20DET
Mods:
HKS 2530
Power FC
Apexi AVCR
460cc Rx7 Injectors
Walbro 500hp fuel pump
All the other normal stuff:
Front mount IC
HKS BOV
HKS POD
Full 3 inch exhaust (twin pipe dump too)
The Wastgate arm has been spaced out with spacers...and has an adjustable boost arm on it, Is longer arm less boost or other way around??? Also
I was hoping for a High and low setting of boost, but i think the arm is set on 1.2bar???
Thanks for your help!!
Luke
If the tuning is ok, then id say the std engine shall be fine, privided it is healthy to start with. Depending on how you drive, your g'box may start to struggle:( Dong to too hardcore with the clutch you use and the gearbox may survive.
My g'box has done 178,000kms and the last 30,000kms have been with between 200-235rwks...and the box is starting to fell its age:(
  • 3 weeks later...
