well... after blowing the cobwebs out of the 32 last nite... the clutchfan decided to begin seizing on and off... overrevving the fan obviously...
nipped on down to FBI to grab a new clutchfan as this one was about to let go at anytime... - got the new fan, threw it in the backseat and off we go
pullout onto the main road... 1st gear... into 2nd... *BANG*
BIG HUGE THANKS TO TREV AND THE FBI CREW TODAY! Wouldnt have made it away from the workshop without you guys!
- adz
oh and heres the pics from the self-venting-input-incident :P
bonnet was just f**ked... so new one now (black)
radiator had 3 cores removed so that was f**ked... got a new one
powersteering pump belt was cut... got a new one of them
powersteering pump line slow leak... still got that - will fix it on the w/e
ill take pics tomoz of the clutchfan... well half of whats left of it!
after putting new rad in and flushing the system... water temp has dropped majorly and the car runs alot smoother :)
also big thanks to mike (TUF200) for letting us use his tools on such short notice and to nicko for helping me out with everything :)
- adz
Rezz the car only just landed on wednesday... so obviously it isnt registered yet - i had a permit though!
my friends rb25 blew up in his r32 4 door... so tomorrow im getting another permit n going up to his house... sitting both cars side by side... and putting all his stock shit on my car... then tuesday put her on the dyno for a quick power run just to see how bad the tune is and what shes making... then i drop the car off at FBI for compliance and prolly wont see her for several weeks
- adz
    • Welcome James.....will be interesting to see how much fun there is in the project. .....where's the pics?
    • Your profile doesn't say where you are, but you can get your current turbo rebuilt by any competent turbo shop, places like Precision Turbos or GCG They can replace the core with a modern ball bearing unit and should be able to source same or slightly larger wheels to fit in you housing. Note if you change the core you may need new oil and water lines too
    • If you are fine with China turbos, Maxpeedingrods makes a bolt on turbo. Ive had mine for two summers now and it seems to be holding up ok.
    • Howdy all Im in a little predicament and wondering what everyone’s thoughts are? I’ve had my long block rebuilt and am in the market for a turbo due to my old one having metal shavings from crank bearings (cause of rebuild) go throughout the turbos oil lines and there wheel has a little play. I’m not really aiming for any power, just trying to keep it as oem as possible, but I can’t find a turbo that’s built for the stock ecu or find something that would be a standard replacement. Anyone have any ideas or suggestions
    • How's everyone going? Just a shout-out introducing myself. I'm James, I live on the north side of Brisbane. I bought an R33 that had been left to rot in someone's front yard for 14 years. Apparently, it has immobiliser/fuel issues. Long story short, it's suffering from a seized engine, plus whatever else turns up once it runs. The car is pretty good considering it sat for so long. It pretty much died after being imported. It has a bunch of Jap parts and a full Top Secret body kit. It's painted Fiat Turchese Festival, or aqua blue if you're not French. Another project to throw money at!
