Hey all...
Have the following for sale..PM or reply to this Thread if interested...
Here we go:
- GREDDY T88-34D
Front Compressor side has been Polished up, No surface rust on the exhaust Housing like used turbo's get over time. TRAVELLED 1000KM in Japan. Was told it made 834.8hp@Wheels on a gtr...
PRICE : SOLD
- ARIAS PISTONS + RING KIT (BRAND NEW)
Suit rb26, Suit bore size of 86.5mm. Pistons are 20thou over. These are brand new and i can provide detailed spec's on the pistons if Someone wants them.
PAID : $1550
PRICE : $1350
- GREDDY PLENUM (RB26) (BRAND NEW)
Never been put on a car...Very clean condition...
PRICE : $1250 DROPPED TO $1000
- AUTO STAFF UP PIPES
Came off a GTR R33. Twin 2.5'' pipes into a 3'' Pipe before the cat...
PRICE : $300
- HKS PRIEST EXHAUST (DIFF BACK)
Limited Edition exhaust came off a GTR R32. Size is around 3 3/4...Is a relatively Quite Exhaust....
PRICE : $350
- STANDARD GTR PISTONS
Excellent condition No Damage
PRICE : $ 250
- STANDARD GTR OIL PUMP
PRICE : SOLD
- STANDARD GTR WATER PUMP
PRICE : SOLD
- STANDARD GTR TURBO KIT
Turbo's,Manifolds,Dumpipes,1 O2 sensor..Travelled 30,000km's NO SHAFT PLAY
- STANDARD PLENUM + Throttle Bodies (6)
Plenum has been Stripped back to alloy look (Like R34 GTR's
PRICE : $ OFFERS
LET ME KNOW
CHEERS
https://www.sau.com.au/forums/topic/67762-gtr-performance-gear/
HAHA....im here!!! Just got back from training For REAL....
I ate oranges JOKES!!!!
Hey chris, Im going to come round tomorrow if your nbot home please leave the parts!! thanx
BUMP
Am interested in turbo, what revs does it come on boost at?
I havent used the T88-34D turbo on any of my GTR's...
But judging from my experience with the T88-33D...That turbo came on about 5700-5800rpm...Other parts such as cams, Intercooler, ECU, Tuning etc...Plays a part with spooling it up...
Let me know
    • Duncan:- it affect both sides.  Driver side is worse.
    • That seems like a very special issue!  Does it affect both sides? Either way, I would disconnect the driver's side switch and see if it still happens, noting that might require removal of the whole door card which is a bit of a pain (it does on V37 and HY51)
    • MBS206:- The windows start to slowly open themselves. GTSBoy:- Battery is new since Dec.
    • I currently have a 2008 370GT Coupe, with the big brakes (Akebeno if I'm correct), and Its coming time to get new pads. Previously, I had a 2003 350GT Coupe with the stock sized brakes, not Brembos. I had custom wheels on it that were pretty open to the brakes, and when I first put the wheels on it, the rims where completely coated with brake dust. A few years after adding the new rims, I needed to change to pads on that car. I didn't do any research, but I told the mechanic of the problem with the brake dust. I also told him I didn't track the car or even drive around the streets harshley. But the dust was an issue. The mechanics changed the pads to a different compound, and the dust was GONE! The other change I noted was that when coming to a complete stop, instead of having to press harder on the pedal as I approached 0kph, I had to actually lift off a little to not come to a hard jerky stop.( My unfounded explanation is they became stickier as they heated by stopping ) Since I got my 370gt with big brakes, I noticed that that as I came closer to stopping, I had to press harder and harder to reach a full stop. I am not talking about hard, just harder. I brought the car in from another state, so when I had a blue slip done, I asked the mechanic what he thought of the brakes, and he thought they were brilliant. The only negative of these pads on the 350GT, was that they squealed when cold. So driving out of a shopping center carpark, it was a little embarrassing, as the brakes squealed, and I am sure people thought that I needed new brakes, when they were actually fresh. I have no idea of what type of compound they were on the 350gt, but whatever it was, I want to get the exact same on my 370GT. They weren't ridiculously expensive, and were replaced at the local JAX (which is no longer open), so I am certain they would be a pretty common big brand, off the shelf type/brand. My current mechanic suggested I need top get the rear pads changed soonish, but he suggested standard Brembo pads. Which I expect to behave the same as the current ones and not like the ones on the 350GT.  I don't think dust will be an issue on the 370GT. With the behaviour I describe above on the 360GT, does anyone have a suggestion of pad material that will act like the change I had done on the 350GT?
    • The consult isn't even OBD1. It's a Nissan Consult. Proprietary.   Re read everything I've said. I specifically say, put down the laptop/tablet. Understand, and review the issue first. Logging voltages is the same as logging the converted value. Things like O2 that you say to log, is unusable for this, whether it be the voltage, or the value the ECU thinks.   The fact you don't know how to diagnose without looking at the computer, is exactly what I've said multiple times is the issue for why techs these days can't diagnose the fun issues with cars.
