SAUers,
Found this old mag (Wheels, July 1990) whilst cleaning out the home office. I scanned it thinking some of you may be interested.
The article cites 576bhp @1.8Bar, driving 1325kg car. That was 15 years ago...
Elsewhere in the mag there is an article on the 'new' 5.0L Ford HO motor. "Ford's brawny V8 is back with a vengeance" and 165kW. :P
Mark
PS I've got it in a larger .pdf that's around 1.8Mb, if it's hard to read or for bigger pics.
PPS Check the filename for the page order, the comp has loaded them back to front.
https://www.sau.com.au/forums/topic/67770-gt-r-group-a-article/
Sent to all above addresses and PM's.
Guerilla: It's no trouble - for what I've taken out of SAU, it's the least I can do.
Intensevil: Thanks dude. If you PM me the link I'll edit the first post to make it easier for everyone else and save the wait. Cheers
Mark
