got a few parts for sale nothing wrond wid them just been upgraded...
1.RB25DET series 1 computer and AFM $120:SOLD
2.RB25det series 2 computer $100:SOLD
3. R33 bonnet with GTR front lip $250
4. R33 standard steering wheel $80
5.R33 standard intercooler $30
6. R33 standard air box $40:SOLD
7. R33 standard grill $50:SOLD
8.R33 GTST standard wheels and tyres good nic, good paint no scratches and bout 50% tread still left $400
9. R33 standard injectors $300
https://www.sau.com.au/forums/topic/67792-r33-standard-parts/
Hey, im just wondering is the bonnet you have off a series 2 becasue i am desperately in need of one because i just had a prang two weeks ago and need one and i will buy it off you asap.
Thanks
Thanks
hey mate im after a rb25 AFM but it has to have a pink sticker on it, NOT green, if its pink ill give u $80 for it as i need it ASAP
call me on 0402 622 317 if its the right one and ill pick it up asap :(
cheers
Brad
Gr33dy your PM box is full, i tried sendin to u but it wont accept!!!!
Yer you can have the to computers and Afm for $250 Delivered!!!!
clear your PM box so i can get some delivery details!
thanx
If you still have the airbox I'll take it. As long as it's complete top and bottom with all the bolts and grommets and also the plastic spacers that go iside the grommets and the clips for the top. Can you send me an e-mail if you still have it?
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
    • BTW, the reason I came in here to "update" this list was that the Garrett G Series II range have been released and I've updated the list with their flow details if you're curious to check how they fit with previous Garretts and other brands The G-Series II G35 990 looks like a banger...
    • Hi all, I thought I'd put one of these references in here before but it seems I haven't - not sure how many people are actually using this place still but I feel like there are guys lurking about who might find this reference useful or interesting.  A lot of the time people don't catch key details or even fully understand how compressor maps work - or don't even look at them and just go from heresay about deciding how different turbos may compare, but I've been putting together this table over the years as a quick reference to get a gauge of how certain compressors compare to cut down the time that can be wasted looking around aimlessly. * This relates purely to compressor flow, so won't necessarily reflect the outright capabilities of these turbos as the power potential also comes down to the turbine side.  If you understand this, you should be able to use this 😃 * The inducer and exducer size listed are the mm of just the compressor wheel * The values under the "psi" headings are "lb/min airflow" and reflect the maximum airflow that compressor supports before it's efficiency dips under 65%, or it reaches it's maximum speed - whichever comes first. Any questions, or requests for other turbos which the compressor map is available for then let me know 🙂
    • And what you pay for a pack of 8 bolts and nuts at Bunnings, will land me 200 of the same nuts and bolts from a fastener shop.   M12 * 1.25 IS a standard. It's not like ordering M12x1.25 and hoping the thread pitch is right. Unlike ordering an ounce, will get you 4 different amounts depending on which ounce someone takes it to be. Your issue is a supply issue.
