HEY WHO WANTS THE BEST DEAL YET!!? R33 GTST , 86,700 k's, silver, under the hood is a STANDARD rb25det,plus, k&n pod filter, 3" cat back stainless exhaust with a 6" tip, a small b/o valve, and a cool down timer! interior is EXCELLENT CONDITION, all original(except stereo, kenwwod cd player), including steering wheel and floor mats, plus tint and seat covers, outside you get a set of twin 5 spoke 17's sitting nicely in good rubber, it has all the fruit you get from nissan, car was complianced in march 2003, has had 1 owner since dealer, LADY DRIVER for past year, not used for past 6 mos. due to me injuring my back at work. we are DESPERATE TO SELL and we are looking for offers over 15,000, EXCELLENT START CAR for a TUNER call stets on 0428 256 882 or 08 9304 4383 car is in perth wa, car is unencumbered, and ready to go please see http://www.carsales.com.au and enter search as follows: nissan skyline series 2 in west aus, please note some photos have been edited to remove some serial numbers, serious buyers can be forwarded original photos, also front bumper was replaced due to lower lip being left on parking curb at shop
https://www.sau.com.au/forums/topic/67795-r33-96-gtst-15000/
Hey Stets, I came and saw this Skyline... you should also mention that its got an EXREEEMLY BAD Vibration when you get upto 75km's per hour.
And you told me that the front bumper got damaged when you drove into your driveway because it was on 2 much of an angle... ??
Im not sure if you know about the car that much, its registered in your name isnt it??? And didnt you did mention to me that you had a GTR at one stage so I thought you would have known that this isnt a series 2.
Ahh well, Id say you should re-advertise it as a Series 1.5 and make note of the vibration that it has.
No hard feelings.
- Adam
* This has been edited.
ok adam, yes it did have a vibration, has had a mechanical inspection, found it to be a worn uni joint, $100 later and smooth as a babies ass, yes the bumper has been replaced, and not painted and yes it is off an earlier model series 1, no arguements there. also after taking it to the mechanic (a specialist), we found out that the car was involved in a very minor front-end accident to the front left and bonnet (in japan), the car was fixed cheaply and series 1 front guards and bonnet where used, so as to match each other. however the car is a series 2 has all the features of a series 2 and is mechanically sound, and we had no problem selling the car to a dealer for a reasonable cash offer, thank you for the $100 deposit that you sacrificed and the dis-respect of not even phoning to let me know that you were backing out of the deal. the $100 deposit you left was enough to fix the vibration and the front bumper was quoted at $250 to respray, i was honest with the reason for sale, my financial situation was explained, and i apologize if you find it so hard to accept that you just couldn't get what you wanted for your commodore, but we got what we wanted for ours and you paid to fix your biggest downpoint on the car which was a small concern in the end. and no my back aint feeling any better, but thanks for asking anyway
    • Getting a decent signal from all 6 throats is a challenge. I don't know for sure, but I suspect that the stock balance tube is not ideal for it. I have done it on an ALFA 4 cylinder (about 35 years ago, so don't ask for too many details). We drilled 4x holes in the manifold runners, put in some fittings and ran hoses to a decent sized (I think it was about 20mm diameter) pipe that ran the length of the inlet manifold. So, it was quite a decent volume. There is a "tuning" balance to be found between the volume of the common plenum on such a thing and the diameter of the pipes running from it to the runners. You need the volume to be large enough to damp out the sharp spikes in pressure signal you get as each runner gets sucked on by its cylinder, but not so large that it becomes too slow to respond to actual changes in MAP. And you need the hoses to be small enough to transmit the signal quickly, but not so small that they delay the signal. You might have to have more than one go at it, if there isn't any actual success based wisdom to be had here. Hopefully there is. Anyway, I would not do it on only a couple of cylinders. I would also not care about "permanently modifying a part". Just bloody drill holes and make stuff better. There is nothing sacred about any GTR unless it is a genuine museum piece that you shouldn't be modifying at all anyway.
    • He's still joining you, he's just delayed it and won't have the fulleh sick ITBs...
    • The strange thing is this is a URAS front bumper (or clone of it). The bumper actually does not sit flush with the GTT hood - You need the addon to make the hood 'long' enough to reach the bumper. I have no idea why they didn't incorporate this piece into the bumper itself.. instead of sticking it to the hood instead.
    • Another thought on this OLD topic: When you paint your bonnet lip, leave a small unpainted back lip/line along the back of the lip, where it rests on the bumper. That way, the line in the back is much more prominent than the gaps in the front/under the lip - and it breaks the hood-to-bumper connection at the "correct" place, when comparing to a GTR. I'm gonna do this with mine this week, so stay tuned for pics!
    • So I'm in the final stages of assembling my single turbo RB30/26 and had a question regarding MAP reference points.  I've seen several recommendations such as tapping the cylinder 2/3 ITB, tapping the intake manifold at cylinder 2/3, or using a point on IAC. First two are doable but require permanently modify part and the third is "out" as I plan to delete the IAC.  All that to say my question is can I used the "bleeder" in the center of the ballance tube as a MAP Reference? I'm running a catch can so I don't need it for the PCV system. My thought process is it "pulls" from all 6 cylinder, and it's between the ITB and the cylinders making it ideal for MAP reference according to what I can find. Thoughts?
