I've heard it is a wise move, particularly on a 15yr old vehicle. I've looked through the service manual, and all I can see is remove the caliper and check for corrosion, remove and inspect the pistons, change piston seals, grease and reassemble.
Have I missed something or is this it? When guys say that had the caliper overhauled and found out that only 2 of 8 pistons were moving, how do you fix it? Lube??
Finally, is it a job for the home mechanic? I remember reading that the DIY overhaul kit was super exy (from Nissan). I'm happy to have a go provided specialised tools are not required.
Any info appreciated, search came up pretty dry.
Thanks
Mark
https://www.sau.com.au/forums/topic/67830-what-is-a-caliper-overhaul/
  • Replies 49
Excessive heat will cause O-rings to bind on pistons. Not changing fluid causes corrosion.
Seal Kits are expensive... but not as expensive as Liberace'ing someone!
Check WRX Calliper kits if they fit (R32 - MY02) have similar sumitomo callipers.
If you are technical, and thorough.. DIY is OK. Need Compressor and some "Brake-Clean" to...
Hope this helps.
TT
GTST calipers, and most likley non Brembo GTR calipers use the same seal kit as OZ deleivered Z32 300ZX and S14 200SX so seal kit is less then $100.
One thing , i have been looking at 2nd hand sets of calipers, and also new, and it appears various calipers can have 3-4 times the flex once they get a few years on them, especially monobloc calipers. (4thou of flex later measured to be 22thou:()
So perhaps consider how much heat cycles have been thru the calipers (street/track??), how many kms as well. I doubt it will couint for squat unless you are chasing the nth degree of performance from your caliper, but im curious to know if calipers do have a finite life????
That's basically it.
The overhaul basically fixes it. What happened in that instance was that brake dust got in under the dust seal, and ended up setting like concrete, totally immobilising the piston.
Can be done, but might require a bench vice to help hold the calipers while you remove the pistons (when I saw it done, the guy used 2 enormous screwdrivers to lever the pistons out, but just on the bench), and a can of BrakeKleeen or similar. Maybe some very fine (1200) paper to smooth out any little nicks in the pistons. If you are careful, you can re-use the O-rings and seals. Otherwise sus out the brake specialists for a kit.
Thanks
Mark
A seal kit for my R32 GTST front calipers was something like $91 from Nissan thru Race Brakes in Nth Melbourne. (thats both front calipers)
The R32 GTST Sumitomo (spelling??) calipers use the same piston diam as the Sumitomo R32 GTR caliper, so i would be surprised if the R32 GTST seal kit cant be used as well. Ring around your local Nissan dealers to see how much for the Z32 300ZX seal kit and S14 200SX seal kit.
Worst case just courier them to Race Brakes and for $120 all up they will order the seal kit form Nissan (perhaps the get a good trade price) and throw the seal kits in for you. its about 30mins labour for them.:) I think it cost me $120 for the seal kit and install and about $90 for HPC coating of the calipers.
You can get the seal kit and DIY for less then $100 for fonts.
The paint was a bit ordinary on my calipers so i paid the bit extra to have them HPC coated, inlcuding the caliper pitons to try and reduce brake fluid temps. Who knows of it really makes any difference, but the theory seems to be sound:)
So you dont have to have them HPC coated or painted, but i figured if its good enough for Harrop, HSV and FPV then it cant hurt my little calipers, even if it just makes them look neat:)
Roy: I meant $200+ to do all four corners.
I have to change the brake fluid on my car shortly (pedal is mushier than I would like), and thought while I was at it I would change the brake/clutch lines to the braided ones I bought. Then I thought, well, why don't I add a set of SpeedBleeders while I am it? Then it occured to me that perhaps I should also overhaul the master cylinder too. And finally I thought, well, what's good for the master cylinder is probably good for the calipers.... :)
As you can see, things are kind of spiralling out of control. And now your implanting the idea of painting/coating my calipers. Gawd damn.
LW.
But can you ever stop fast enough? Hell if we were talking about going forwards doesnt matter as much, but we are talking about whats potentally the last safty device before the car crashing.
Just spend the money and fix it!
I've just done all 4 calipers on my R32 GTR - new seals and boots. You can get the kits to do front and rear for around $100 through ABS. I posted the kit PN's in another thread sometime back, but will do so again here if needed.
The important thing is to ensure the piston bores are clean and there's no corrosion on the pistons themselves. As someone else suggested use fine emery to clean up the outside of the piston (DON'T use emery on the piston bores). Above all make sure everything is absolutely clean.
I use compressed air to get the pistons out.
Targa Tom, Roy, blink_elk: thanks very much for the info, I'll give it a go myself. Have compressed air, will travel.
SteveL: I searched a while for anything related, but couldn't find the thread where I last read about it - probably the one you're talking about. Could you pls post the PN's and the ABS site/contact details? I'm guessing they're not "Applied Business Solutions" (abs.com.au) :(
Thanks again guys
Mark
Hopefully another couple of handy tips.
Check under the seals to see if you have any buildup underneath them and make sure you clean them out. I used a piece of wire flattened at one end and bent at 90 deg to slowly scrape them out, you can use a Dremmel with a wire brush end if you are carefull.
When using compressed air to blow the pistons out which is a great way to do it, leave the pads in the calipers to stop the pistons flying out and gradually use something thinner as you go along. Last time I did this was on a bike and the piston came out with a bang and went flying across my w/shop.
Scared the shite out of me.
It's not a big job but make sure everything is clean, really clean before you reassemble everything and the hardess part is bleeding the buggers afterwards.
Gary
ABS = Auto Brake Service, check Yellow Pages for a local franchise.
PN's for the caliper kits are:
Front - SJ6070
Rear - SJ6024
1 kit does an axle set = 2 calipers. I paid $100 total for both kits.
These kits are to suit R32 GTR calipers which are the same as Z32 as well as R32 GTSt and R33, I believe (I can double check in FAST if needed).
Oh and definately take care when using compressed air - only a low setting is needed.
SteveL: I searched a while for anything related, but couldn't find the thread where I last read about it - probably the one you're talking about. Could you pls post the PN's and the ABS site/contact details? I'm guessing they're not "Applied Business Solutions" (abs.com.au) :cheers:
Thanks again guys
Mark
www.autobrakeservice.com.au
    • Yeah. air pressure leakdown test is where I would be headed next here, using one's ears to determine whether it's the valves or bores/rings leaking...
    • More likely you didn't bed the rings in correctly and have glazed the bores. Running with misfires on a fresh build is somewhat of a no-no. Surely no-one "smoke tests" the combustion chamber? That's what a leakdown test is for. Smoke testing is, um, a bit of a wank at best, and only really useful for external pipework.
    • Well, obviously that kit is not a relocation kit or anything other than just the original isolators and the like. I would suggest that it should be a matter of just bending up some flat bar to build a mount over the top of some other diff, with the flat bar held to the back of the diff by the rear hat bolts. A little welding, a little thinking about how to secure the front of this structure, maybe some different hoses in case you can't get it in just the right place.
    • Pay diff/trans workshop to do this.   Nope. Z32 turbo ran R230 with 6 bolt GTR style axles. All other Z32 were R200. Basically same same as other R32 stuff. All were a viscous waste of space.
    • So, I'm not a diff swapsies specialist, but I am pretty sure the 300zx ran an R220 not and R200 like the C34 Stagea, so I think it is of no use to you. As you said, all you need to do is get the centre swapped in the diff you have, which might be best done by a diff specialist. The current centre is probably desirable to someone to track so an easy path might be to swap your mechanical centre for someone with a standard centre (which is a viscous LSD, and almost certainly won't have any limited left). The only thing you have to watch swapping R200 internals between diffs is that the number of splines on your car's stub axles has to match the donor car, or you need the centre+stub axles and make sure they have the same number and pattern of bolt holes as your rear axles.  You swap your current ratio onto the new centre so you don't have to worry about matching the front. Alternatively, centres like the Nismo pro are much gentler (and have adjustable "tightness") so you could buy on of those from somewhere like Jesse Streeter or Nengun (noting it may cost you 1234% extra in tariffs by the time it lands)
