Hi guys,
Yesterday my auto transmission stopped changing gears and started slipping in which ever gear i could get it into except for first gear.
In first it feels totaly normal... I can't even get it to change gears properly when i select it.
Does anyone know what is wrong? or does any one have a gear box they could part with cheap?
My only car and I know bugger all about auto's :)(
If anyone can help that would be wonderful.
Thanks
https://www.sau.com.au/forums/topic/67853-urgent-auto-trans-died-please-help/
Sounds like one of the bands isn't grabbing anymore. I'm not sure if they break or just slip badly. Did this happen gradually or all of a sudden?
They are pretty much the same transmission from R31 to R34 so an aut transmission place should be able to help you without too much expense.
Are you testing the fluid level when it's hot and the car is RUNNING.
I can only compare to my old VP but i had auto troubles, fluid level looked fine but I was checking it when the car was switched off, as soon as i did while it was running the dipstick came out DRY! :P
Turned out the pipes to the trans cooler where cracked and leaking (the power steering was leaking too so i thought all the dropped fluid was from that) after replacing them and top up it was right as rain.
have you been reving it in netral then dumping it into gear if you have then you are experiancing severe slippage
sometimes if you leave the car off for a while and let it cool down fully it will return to normal :P
im having similar problems with my sigma (shut up!)
start it, rev it moderately to get it to go and it shudders and hops forward a bit, with the sound of grinding, it goes for about 20metres then it disconnects, just like putting the clutch down in a manual. then you turn the motor off and 'let it cool'. then you start again and it goes for a while, then screws itself again. i havent really had a chnce to have a look under it, but i want to tighten the bands and change the fluid. but its at the bottom of a hill and my shed is at the top...might have to tow it back up.
can anyone help me on this? is it purely fluid related, or is it tearing itself apart?
    • As you're looking at using a Link ECU, then large injectors are not a problem. But there's not really any need to go 1000s on an RB20 unless you're planning >>600HP on E85, which would seem unlikely. There are other options for injectors. The Xspurt ones are available from a number of places and you can get them in the mid 600s and 725cc, which is probably a sensible place to be. These are all EV14 based. If you are not using the stock AFM (at all, which would be the case with a Link) then a large turbo intake pipe to suit the ATR turbos is not an obstacle, so you should use one instead of a highflow. Results will be better.
    • Hey guys,  I'm after some advice and this here is the best place to get it imo. I was a member a looong time ago under another account, with a lost email address. Its nice to jump back on and see some of the same names still giving good advice.  I mothballed my car when i moved to perth in 2013, and after getting towed across the nullabor a few times it has officially done more km's on a trailer than under its own power. Now that i have started the process of tidying up and modifying it, i see the fruit available (and the fruiterers selling the produce) is different than back in the day. hence my questions, as i used to 'know' what to get and now, i'm not so sure. Engine wise the car (92 gtst) has a walbro 255, k+n, fmic, cam gears and and turbo back 3"exhaust. Wish list is a Hypergear high flow or ATR43G1, Link G4x and some newer injectors before a tune up. My goals are modest, only low 200's power wise. i know i could achieve this with less, but i've been swapping out old for new where i can. Every cooling hose has been replaced, along with mani gaskets, WP, thermostat and radiator, fuel pump and timing belt, tensioner and idler, and i rebuilt the steering rack. Regarding the injectors, the fruiterers all seem to sell what used to be considered quite large injectors. There are a lot of options for bosch 1000cc EV14's, and i would like to know if that is a suitable choice for my build. Is modern injector design good enough to run these at the low duty cycles that i likely would be? is there a downside to running a too large injector these days? or, would there be an upside to running a smaller injector at higher duty cycle? I can see that there are smaller injectors still available, but the ones i have seen specifically marketed for RB's are pretty large (see: https://golebysparts.au/collections/fuel-rail-injector-kits/products/nissan-rb20-fuel-rail-bosch-980cc-1150cc-injectors-turbosmart-fpr800-regulator-kit), and i dont know enough about them to say one not marketed for RB's would fit or not. I have searched the forums, and amongst all the posts on older tech, I did see gtsboy recommend EV14's, but no size was mentioned... again, i'm not clear on if the smaller size bosch injectors are also EV14's as they do look similar.  also, if someone can recommend a tuner familiar with RB's in the Geelong or West Melbourne area i'd appreciate it. Thanks in advance guys. Cheers, Rowdy
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
    • I mean, if you were to move the jacking points away from the original location, that is, away from the wheels and closer to the centreline of the car, then it will be more likely to overbalance and tip off the supports. Same as we talked about before. I was talking about moving for-aft. If the sill is bent outward or inward, then the car would obviously look unstraight from the outside. Hopefully that hasn't happened either. Again, you can do comparative measurements from the chassis rails to see if there is much deflection.
    • Can you elaborate what you mean with your first sentence? I meant move as in the bulge kinda seemed like it got pulled "outward" meaning it got pulled down and to the side with the jacking rail itself, so the load bearing bulge now sits lower than usual and is not level with the sill on the other side of the jack point. Either that or the jacking rail just got pushed in a good bit.
