SR is an alloy block, 4cyl
RB is a cast iron block, 6cyl
heaps of other differences... stock for stock, I think the RB has *slightly* more power, but *slightly* less torque...
someone who can be bothered to explain it all will be able to help out further :(
EDIT: some info!
RB 20DET
Production Started in 1984
Engine Spec's
RB20DET:
Eng./Size: 1998cc
Head: Alum., Crossflow, 4valve, Dual Cam
Ignition: Transistor/Electronic
Induction System: EFI
Compression: 8.8:1
Bore & Stroke:
Block: Cast Iron, deep skirt design
Turbo: Ceramic Coated
Does anyone know what SR stands for?  Cause RB was for Race Bread.
Don't make me hit you........ :fight!: (too late) And unless you are referring to a particularly racey piece of toast, I think you mean 'Race Bred' (which is still BS).
LW.
SR is an abbreviation for ste·ra·di·an
A unit of measure equal to the solid angle subtended at the center of a sphere by an area on the surface of the sphere that is equal to the radius squared: The total solid angle of a sphere is 4^pi steradians.
duh
LW.
sorry, it's monday what else do you expect.
  • 4 months later...
