']Full set of R33 GTR rims in great conditon, with tyres with 60-70% on them, going cheap $1600
Located in Sydney (Kellyville)
call me on 0410496449  or just message me.
thanks
Tyre brand and size?:(
sorry i looked at the tyres again and they are about 50%. They are Michelin Sport SC. Yeah i have pix just post an email address.... they are in great conditon, only 1 has slight rash, some of the best condition R33 GTR rims around!!!
