Thursday 24th of March, 2005 - Thursday Night Mystery Cruise
  • Replies 102
You say that every cruise, and then there's always one more :)
yea I know coz I keep prolonging paying the fine, but I have to pay it friday or they start sending mean letters :P
Meh I currently have oh look ALL of my points, and have not gained one infringement (touchs wood) nor 1 fine, nothing since buying the line 18+ months ago.
Oh and dont forget to get mummy to pack your lunches when she drops you off at work..... ;)
Girly excuses... Real men don't bat their eyelids at the pigz0rs and prepare their kneepads to get off fines... We take it on the chin and then say fark you very much cruntstable...
I've only ever lost points for speeding...
I went through a speed trap lastnight unfortunately, i saw the flash...so im awaiting to see if it was me or someone else that got done...it was in a sixty zone and was a little way down from a corner i came out of, so im not sure as to what speed i was doing, somewhere between 60-80 id say
Real men make legal threats and make it worse off! Woot Woot!
And on an on topic note, I cbf coming in the Barina-dogg. Unless I know where we will end up.
ska = pwned...
Only real men have no license eh Matt...
you got it....no license required, just shows youve gone hard enough...not to mention the few ive gotten away with...im in front (i guess) :( And as for you cyrus...all your points, thats a joke, how the hell do you keep them, clearly your driving is weak sauce :) jk
you said it...i lost my license due to speeding...but there were a few other ones in the mix, undue noise, increasing speed beside on overtaking police officer, etc etc....meh skids are teh way...fines cant stop that :(
Actually I'm not a cheapskate except, well, actually I am, so is that $30 UHF at DSE good enough?
good so long as you only want to talk to the person next to you....
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
