hey guys,
just in the process of ordering a 2-way for the Ceffy. on the order list there is a model for R32, Cefiro and S13. well ive narrowed it down to either A31 or R32. as the car was converted to an R32 manual im not sure wether it uses the A31 rear end or R32. also the engine was swapped for an R32 RB20 so im guessing the original car may have been a non turbo, hence non-lsd, but now deffinetly has an lsd.
i might take a photo later on tonight, and maybe get someone to host it for me?
but im also guessing that R32/S13/A31 diff centers would be pretty straight forward to interchange am i right?
cheers for the help! :(
EDIT: also when buying swaybars i just order S13 type? and also does anyone know who can source turbo gaskits for an HKS 2530?
Phil
https://www.sau.com.au/forums/topic/68000-which-diff-centres/
I have just ordered some S13 swaybars also, I am 99% sure they will fit as all the other suspension components are interchangable with S13.
The diff centres can be determined by looking at the amount of bolts on your halfshafts. IE: the shafts that come out of either side of your diff will be attached to your shafts by either 5 or 6 bolts.......R200 = 5 bolts evenly spaced and R180 = 6 bolts in 3 groups of two.
Hope that helps, if you have any further queries just send me a PM.
