GT4 online????
Archie@
 Share
Not sure if any of you guys have looked into this yet but there is sort of an online racing option.
It's actually the LAN game settings, but if you hook your ps2 up to your pc and use a tunneling program, it tricks the ps2 into thinking that it's hooked directly into another ps2 and not thousands of miles away through the net.
The catch is the you would need an excellent internet connection. Here is the link for the tunneling software. clicky clicky
Let me know if any of you are interested, cause i'm picking up an extra network card in a day or two, and i'm gonna give this a go.
I'll post up how it goes, if connection is ok, etc....
If it's good, we can start a comp on Burg...hehehe
Archie, with this software you dont need an extra netwok card if you have a router with a spare port or a switch hooked up to a router. There is a thread about it in the Whirlpool gaming lounge, can't give the link because its a protected forum.
Copy and paste:
Originally posted by MickJT on http://forums.whirlpool.net.au. Direct link: http://forums.whirlpool.net.au/forum-repli...es.cfm?t=312698 (you have to be a member with a certain number of posts)
So, you've read all of the current documentation and just can't get it going, right? Can't get past the "Waiting for connection" screen? Read the notes surrounded by asterisks.
This guide is to help everyone out there get Gran Turismo 4 working Online, by using XLink Kai: Evolution 7 to trick Gran Turismo 4 into thinking the Internet is one big Local Area Network.
The requirements (for this guide) are as follows:
- A new slim PS2 or PS2 with Network Adaptor.
- A PC with Windows XP.
- A PCI Ethernet Network Interface Card not in use.
- An RJ-12 crossover cable.
- Gran Turismo 4.
- A broadband internet connection. 256/64 minimum (2 player only).
Bandwidth used is 5kB/s per player (not including yourself),
for both downstream and upstream.
Examples:
Bandwidth (2 Player): 5kB/s downstream, 5kB/s upstream.
Bandwidth (3 Player): 10kB/s downstream, 10kB/s upstream.
The bandwidth used does not change wether you are hosting or not.
All users must have a latency of under 60ms for acceptable gameplay.
Hook up the RJ-12 crossover cable from the PS2 into the spare Network Interface Card in your PC.
Go to Control Panel, and double-click on Network Connections. Right-click on the connection that is directly connected to the internet, and click on Properties. Click on the "Advanced" tab, and tick the option that says "Allow other network users to connect through this computer's internet connection". Then click on OK.
Go to www.teamxlink.co.uk and create an XLink tag (click on the Sign Up link at the top).
Download XLink Kai: Evolution 7 for Windows XP.
Install the program and open the configuration tool "Start Kai Config" in the Start menu. Under Profile, select "Normal Kai Use" and select your NIC (Network Interface Card). Enter in your XTag and Password and tick Auto Login and click OK.
Load up Gran Turismo 4, and get to the first screen where you can choose between Arcade Mode and Gran Turismo Mode.. Scroll down and select Options.
Under "Arcade Mode", select "LAN Play".
Set your "Machine name" to whatever you like.
Set "Host" to "Yes". (even if you are not hosting.. you will set it back to "No" afterwards)
Set No. of players to "2".
Set No. of monitors to "0".
Set Monitor type to "Normal".
Set Network Traffic to "Light."
If you will be Hosting, leave that option as Yes, if you will be Joining games, set Host to "No".
Save your settings.
Go into "Arcade Mode" and select "Multi LAN Race". If there is no Network Settings there, then do the following:
Select Create new network configuration
Default Hardware settings are fine.
Enter in the name of your ISP for "Name".
Authentication "No"
User ID blank
Password blank
Use DHCP "Yes"
Use auto DNS "Yes"
Click OK.
Start XLink Kai ("Start Kai" in the Start menu).
An MSN type Window will appear.
Back in GT4, select the network configuration you will use, and select "Connect". You should see "Waiting for connection"..
In Kai, click on the tiny icon of a Globe, at the top of the window, then click on the tiny icon of a magnifying glass at the top of the window.
Make sure you can see "Network Reachable: Yes", then click on the icon of a Folder at the top, and make sure it says "Sony Playstation 2 Configured successfully".
Back in GT4, press Square to exit the "Waiting for connection" screen..
Now this is where the annoying part starts.. Everything must be perfectly timed or you'll stay stuck at the "Waiting for connection" screen..
****WHAT THE OTHER GUIDES DO NOT TELL YOU****
The amount of players you are going to play with, must match the number of players you set in the "LAN Play" settings. See the Note under the "Joining a game" section.
You need to correctly set your Kai status when it asks for one.
In Kai, click on the Globe icon. Then on the green arrow for Playstation 2, green arrow again for GT4. Click on the green arrow that corresponds to the area of the world you live in.
Now, this must be set correctly. If you will be hosting a game (which is the preferred option), everytime the option to set your status in Kai comes up, select "Yes, i'm hosting now". If you are not going to host, then select "No, i'm trying to join". Then click on the green arrow to set that status.
If you look at the Kai window, there is a very long thin button in the middle of the right side of the window, click on that to expand it and reveal the chat window.
--- Joining a game ---
If you will be joining a game, wait until a new arena appears and immediately join it, and press "Connect" in GT4 to get to the "Waiting for connection" screen, the moderator of the arena "should" then ask if everyone is at the WFC (Waiting for connection) screen, and you and the other people in the arena should reply back
letting the moderator know you are ready, and then the moderator will start the game by clicking "Connect" on his side.
*** The big problem joining a game is that the "No. of players" setting that the Host (moderator of the arena) set in the "LAN Play" options, is not very likely to be the amount of people in the arena trying to join the game. This will cause the "Waiting for connection" screen to stay there forever unless the amount of players is at least the amount the Host set in his "LAN Play" options. This is why hosting a game with a friend is a much better option ***
--- Hosting a game ---
To host a game, click on the Icon of a Globe with a cable coming out of it. Give your arena a name, and set the number of players to the amount of Players you chose in the "LAN Play" options in GT4.
Wait for the correct amount of players to reach the "Waiting for connection" screen, and then click on "Connect" in GT4.
*** Note: The host (you) joins the game LAST after everyone else gets to the "Waiting for connection" screen. Also note if you have selected No. of players "6", then you must wait until 5 people are at their WFC screen before you try to start the game. ***
The notes surrounded by asterisks here should give people reasons why they cannot get past the WFC screen..
Note: If you still cannot get past the WFC screen.. Have the Host restart both his/her PS2 AND XLink: Kai Evolution 7. This has been proven to fix problems where you are stuck at the Waiting For Connection screen.
I hope this helps everyone out.. Thanks for taking the time to read it all :P
Thanks for Daizer for contributing on a mild level :)
[Edit: Bandwidth usage update.. and extra note on what to do if it still doesn't work]
If you have a router.. You should just be able to run a patch cable (aka straight-through cable) from the PS2 to the router/hub/switch and then proceed with the instructions from the download xlink stage ;)
I'm not using a router atmo, and since i have a spare network card i thought it might be the cheaper option, this way with a bit of tricky wiring and a network adaptor cable for the ps2 it should run well. but i did consider using a router at one stage.
Thanks for all that extra info, gonna go read through it now to see if maybe another option is better suited. I was just thinking $$$ atmo as i've spent a bucketload on GT4 with the steering wheel and all.
From a couple of threads around I gather that the lag is dependant on ping rather than then the number of players. The rule of thumb is that under 70ms is sufficient for up to 6 players, as long as all of them have enough bandwidth (5k per player).
Well a guy on another forum done a 6 person Lan and he said that anymore than 4 it would lag and that was on LAN.
Really?? I stand corrected then... We should have an SAU GT4 meet-up. Will need like a warehouse so you could fit all the tellies, ****pits, bean bags (adjustable racing seats) etc... That'd be cool.
  • 4 months later...
hey so did any1 get this to work?
Nope, i ended up getting a router cause i've got two pc's networked now, so i tryed the easy way.... everything works fine accept for the software x-link, which dosn't want to recognise my ps2 for some reason. normal online gaming works fine on the playstation... so i'm not sure what i'm doing wrong and well i got a bit disintrested as i've been busy... but maybe someday i'll get off my ass and try again.
 Share
    • Right.  I'll try my best at a concise "bring you up to speed" on stuff that may be missing here - obviously open to questions or further input from others as relevant. Here's a datalog from a responsive turbo setup with electronic boost control being used a bit, to keep it simple I've marked 3 points of interest.  All of these charts are on the same time scale on the X-axis, so you can reference what engine rpm is doing in the top graph, boost and EMAP (exhaust backpressure) in the second graph, and turbo rpm in the bottom graph. A) The turbo gets it's power from exhaust gas, and pumping air takes work.  As a result you can't just spin a turbo with a fixed amount of exhaust energy and expect it to keep spooling - the bigger the turbo (ie, the more air it can push) the more exhaust energy you need to drive it.   The most obvious ways of getting more exhaust energy are by adding displacement, adding boost, or adding rpm - but as you add any of these the turbo also needs to do a bit more work so there is a big balance of these things needed to even get to your target boost and sometimes that's not even possible. What you can see in step "A" is that there isn't enough engine rpm or boost to reach the level we want, so this is where "lag" is.  The dyno run continues and rpm increases, which gives enough energy to increase boost, which helps spool  the turbine speed up even more - so you can see that the rate that the boost (and turbo speed) are starting to ramp up faster than the engine rpm is, so turbo is really starting to wake up as the graph gets closer to point B....   B) At this point we've been able to reach the boost that is actually desired at this point.   To stop the boost from going further than this the wastegate will open and bypass gas past the turbine, meaning it doesn't continue accelerating at the point it was before but instead carry on at a more progressive rate which matches what the engine needs.   The wastegate will have a spring in it which is rated to a specific pressure where it will start bypassing, but electronic boost control (managed by the ECU) can adjust how much pressure the spring sees in order to allow some tunability on how much boost the wastegate actually sees, and therefore how much exhaust it bypasses.   The tune in this case stops boost from ramping up HARD at around 21-22psi just before 4000rpm, then as the rpm continue it allows boost to continue up to around 25psi higher in the rpm.   You can see the turbo speed fairly steadily increases through the rpm to ensure it's keeping up with the increasing airflow demand due to the engine speed being higher and boost being pretty steady.   If the boost dropped off after a point then you may see the turbo speed level off or even drop.   C) You can see that despite the boost pressure staying pretty flat here, the exhaust pressure is steadily increasing and at this stage has overtaken boost pressure.   This isn't unusual, and is largely as a result of the increasing energy needed by the turbo to pump more and more air to suit the needs of the engine as it revs out further.   There are a bunch of variables in regards to how much back pressure there will be on a given turbo etc, but its one of the factors we manage when sizing and tuning a turbo setup.   When exhaust back pressure starts exceeding boost pressure you will eventually start seeing signs that the turbo is running out, the engine gets less keen to make more power and it gets harder to raise boost further. In this case it's a fairly acceptable compromise for the power level (around 630kw on a 3litre engine with full boost by 4000rpm), but you'd not want to push it a lot harder than this.  The maximum speed rated for the compressor wheel on this setup is around 125,000rpm so you can see its starting to get close on that side as well - I feel like this kind of illustrates some of the turbo related things we both decide on how far to push, and are also limited to how far we can push depending on the parts combination. Hope this helps more than it confuses things
    • For that influx of Spammers we had I made no pic posting and no PM's for first ten posts. This is group based and I've manually updated @Beanie to the Members group which will open up the images and PM's.
    • Thx for the reassuring reply. I’ve got above legal clearance  going in for roadworthy Friday… fingers crossed it’s keeping me awake  bloody nanny state
    • I was actually going to try and dig out a datalog with turbine speed and EMAP haha
    • Wait until @Lithium posts a compressor map and tries to explain what's going on. There is a strong possibility that the OP lives in a digital world and is not comfortable with analogue machines. A turbo is just about as analogue as it gets, with plenty of non-linear behaviours added in on top. Most of us who think we know how they work are actually only getting by on 2nd and 3rd order mental models that abstract away from the actual physics and bring it back to the sort of kindergarten level concepts we can hold in our heads. This is important when you need to hold 10 such concepts in your head at the same time. You need to reduce the complexity of the individual concepts to allow them to be simultaneously held and manipulated. Too much complexity in the base models makes it very difficult to make them work with each other mentally.
