  • Replies 167
By the way Benm's car has adjustable exhaust cam gear which we have seen 15rwkw alone with that mod on RB25. It was also more than 9.5psi more like 12 or 13psi to make close to 200rwkw.
We have done the dyno test and as I stated made lots more power than it should have with the mods but only way we will know for sure is to do a back to back changing plenum only. This is the big part of the gain but keep in mind the quality intercooler also would give a bit more power. To stop the beer talk we will also do a flow bench test and we will be doing this over next few weeks and we will put the results on this thread and our website.
Not only compare top end but mid range as well. Not only will it make more power but safer as more even air flow to each runner and cooler. Bonus bit is the bling.
Re the price they may work out less yet as have not finalised the price and no price on our site yet. For those that know me I often tell how much things actually cost even show invoices. I am not a rip off but have over heads and three kids and a race car to feed, he he.
*rubs eyes*
(http://users.on.net/~blakrok/198rwkw-small.jpg)
3000rpm to 5000rpm = hovers around 12psi
5000rpm to 6400rpm = drops to 9.5psi
6400rpm to 7000rpm = steady at 9.5psi
Looks to me like the peak power is at around ~6500rpm @ 9.5psi?
Back on topic...
How long until these plenums are likely to be available in the shop?
Yes boost does drop off and yes 12 psi to 9.5 ish debatable what boost is measured at but yes high in revs the boost is lower as they often do? Do you remember what difference the cam gear was in power? What boost crontrol do you have?
When is the question I am scared to guess but SOON.
It made an extra 10rwkw at peak power (dyno graph here). It's a Greddy gear fitted and tuned (-4) at UAS.
A 3+ yr old TurboXS dual-stage bleed valve (doesn't have the regulator that the new 1's have). Soon to be an AVC-R ;)
Nope, never seen one of these, despite many years of looking. I always seem to find a reason, you just have to look hard enough.
Yes and no. I think that with mass produced vehicles that sometimes everything just lines up that much closer to spec, and by luck everything balances just enough better than normally to make the whole thing sing.
Examples for me have been cop cars as my mate was a pursuit car driver for a while. The early XR6's would top out around 215 to 225 km/h, but there was one that did 240. (Yes the cops have a private track to test these things on.) There was that XR6 and a VP Commodore V8 out of about 150 cars that all the cops that drove them knew were freak cars.
All that said perhaps if you pulled their engines apart and weighed and measured (in every way) every part of them you would find the real reason; rather than the "oh it's a freak" answer.
Also... we have been discussing Bens car for a while now and while he seems happy to take the blame as driver error for his performances; 200rwkw and only 14 seconds down the quarter? Doesn't add up.
Excuse me.  You are Sydneykid.  That means no joking.  I'm not joking.  Well, actually I am joking.  You were joking weren't you?  Haha, just joking.  I knew you were joking.
I measured a tree doing 45kph with a Police Radar once, no it wasn't turbo'd. :wassup:
  • 5 weeks later...
i have just spent a while looking at this thread.
in all honesty i truly belive that $1500 to get a throttle body located at the front of the engine bay is madness, expecialy when you still have the stock bottom half of the factory intake runners bolted to the engine.
as for putting shit on the greddy intake......well that just takes the cake for me!!
fancy anyone saying that a company like trust/greddy cant make an intake as good as one slapped together in australia wich still uses the stock bottom half and a shiney peice af aluminiam on top, what a rip off!!
i think we all should put our heads together and help out greddy because they obviously dont know what there doing??? they proberly dont even test there products??? maybee there got no idea whatsoever??? mmm i wonder if they even heard of the word nissan???
dead set!!
dead set!!
Talk about calling kettle black, strong opinions on tested and proven opinions. If you believe the hype that all Jap products are the best then you need to have a closer look as someare not. Yes from our dyno tests and other workshops I have spoken to the Greddy Plenum loses power which I was suprised at first. The runners are too short so bottom end will be lost and the runners are possibly too big and inside very rough disturbing air flow. There is nothing wrong with factory runners so no need to change them. Yes we have flow bench tested the stock plenum and there is a huge difference in air flow which is not good for power but more so dangerous when winding the boost up as the middle runners get much more air than the outside ones. Also did you forget the dyno result. Plazmaman does not slap things together, you obviously don't know what you are talking about and not heard of him or seen his work. You also mentioned getting the throttle bolted on the front well Greddy does this also so? If we had a rough cast plenum and called it UAS and Greddy came out with a nicely made one like ours I am sure you would be arguing the opposite. We do not have a Greddy Plenum to test but if anyone has one they want to lend us then bring it on. We are still waiting for James from Abrasive Flow Engineering to make a jig to flow bench test the Plazmaman one.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
    • Every one has seemed to of have missed . . . . . . . The Mazda Cosmo . . . . . . what a MACHINE ! !
    • I might have gone a little more South Efrican.  But this is off topic.   😍😍 FD 😍😍
