  • Replies 167
By the way Benm's car has adjustable exhaust cam gear which we have seen 15rwkw alone with that mod on RB25. It was also more than 9.5psi more like 12 or 13psi to make close to 200rwkw.
We have done the dyno test and as I stated made lots more power than it should have with the mods but only way we will know for sure is to do a back to back changing plenum only. This is the big part of the gain but keep in mind the quality intercooler also would give a bit more power. To stop the beer talk we will also do a flow bench test and we will be doing this over next few weeks and we will put the results on this thread and our website.
Not only compare top end but mid range as well. Not only will it make more power but safer as more even air flow to each runner and cooler. Bonus bit is the bling.
Re the price they may work out less yet as have not finalised the price and no price on our site yet. For those that know me I often tell how much things actually cost even show invoices. I am not a rip off but have over heads and three kids and a race car to feed, he he.
*rubs eyes*
(http://users.on.net/~blakrok/198rwkw-small.jpg)
3000rpm to 5000rpm = hovers around 12psi
5000rpm to 6400rpm = drops to 9.5psi
6400rpm to 7000rpm = steady at 9.5psi
Looks to me like the peak power is at around ~6500rpm @ 9.5psi?
Back on topic...
How long until these plenums are likely to be available in the shop?
Yes boost does drop off and yes 12 psi to 9.5 ish debatable what boost is measured at but yes high in revs the boost is lower as they often do? Do you remember what difference the cam gear was in power? What boost crontrol do you have?
When is the question I am scared to guess but SOON.
It made an extra 10rwkw at peak power (dyno graph here). It's a Greddy gear fitted and tuned (-4) at UAS.
A 3+ yr old TurboXS dual-stage bleed valve (doesn't have the regulator that the new 1's have). Soon to be an AVC-R ;)
Nope, never seen one of these, despite many years of looking. I always seem to find a reason, you just have to look hard enough.
Yes and no. I think that with mass produced vehicles that sometimes everything just lines up that much closer to spec, and by luck everything balances just enough better than normally to make the whole thing sing.
Examples for me have been cop cars as my mate was a pursuit car driver for a while. The early XR6's would top out around 215 to 225 km/h, but there was one that did 240. (Yes the cops have a private track to test these things on.) There was that XR6 and a VP Commodore V8 out of about 150 cars that all the cops that drove them knew were freak cars.
All that said perhaps if you pulled their engines apart and weighed and measured (in every way) every part of them you would find the real reason; rather than the "oh it's a freak" answer.
Also... we have been discussing Bens car for a while now and while he seems happy to take the blame as driver error for his performances; 200rwkw and only 14 seconds down the quarter? Doesn't add up.
Excuse me.  You are Sydneykid.  That means no joking.  I'm not joking.  Well, actually I am joking.  You were joking weren't you?  Haha, just joking.  I knew you were joking.
I measured a tree doing 45kph with a Police Radar once, no it wasn't turbo'd. :wassup:
  • 5 weeks later...
i have just spent a while looking at this thread.
in all honesty i truly belive that $1500 to get a throttle body located at the front of the engine bay is madness, expecialy when you still have the stock bottom half of the factory intake runners bolted to the engine.
as for putting shit on the greddy intake......well that just takes the cake for me!!
fancy anyone saying that a company like trust/greddy cant make an intake as good as one slapped together in australia wich still uses the stock bottom half and a shiney peice af aluminiam on top, what a rip off!!
i think we all should put our heads together and help out greddy because they obviously dont know what there doing??? they proberly dont even test there products??? maybee there got no idea whatsoever??? mmm i wonder if they even heard of the word nissan???
dead set!!
dead set!!
Talk about calling kettle black, strong opinions on tested and proven opinions. If you believe the hype that all Jap products are the best then you need to have a closer look as someare not. Yes from our dyno tests and other workshops I have spoken to the Greddy Plenum loses power which I was suprised at first. The runners are too short so bottom end will be lost and the runners are possibly too big and inside very rough disturbing air flow. There is nothing wrong with factory runners so no need to change them. Yes we have flow bench tested the stock plenum and there is a huge difference in air flow which is not good for power but more so dangerous when winding the boost up as the middle runners get much more air than the outside ones. Also did you forget the dyno result. Plazmaman does not slap things together, you obviously don't know what you are talking about and not heard of him or seen his work. You also mentioned getting the throttle bolted on the front well Greddy does this also so? If we had a rough cast plenum and called it UAS and Greddy came out with a nicely made one like ours I am sure you would be arguing the opposite. We do not have a Greddy Plenum to test but if anyone has one they want to lend us then bring it on. We are still waiting for James from Abrasive Flow Engineering to make a jig to flow bench test the Plazmaman one.
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
