Well, it looks like I'll be ditching the boring family wagon and getting a deceptively boring-looking family wagon. (If that's too cryptic, it means I'm selling the Liberty and getting a Stagea.) I hope to have it by my birthday in mid-April. Hopefully I've done my research, and am getting a good deal. I'll have dates confirmed by the end of the week.
At this stage, it looks like it'll be a dark-green '97. The G-Tech, Jaycar IEBC and DFA are ready and waiting... :P as are my mates with their Fozzie GT and Legacy GT-B.
I can't wait, and neither can the missus, even tho she doesn't drive...
https://www.sau.com.au/forums/topic/68053-trading-up-at-last/
  • 1 month later...
Well. Thank GOD the Subie is gone... Stagea will (finally) be mine! Muaahahahahaaaaaaa!
It only took 8 (eight!) weeks to move the scooby-doo. Waiting for funds to clear, and hopefully will be in the Stagea early next week. FINALLY, the IEBC, G-Tech etc will be taken of the shelf, dusted off and put to good use.
I cannot describe how good it feels to be on the home stretch. However, I am looking forward to feeling even better when I drive it home from the importers... :D
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
