Hi All,
I have been trying to make some improvements to the R32 GT-R Workshop Manual PDF that's floating around as I find its pretty unusable in digital form.
Anyway, after a couple of hours work I give you the improved workshop manual with rather complete bookmarks (make sure you open the bookmark tab in Acrobat) :D
Download the Zipped PDF (~21Mb)
Mirror by Amaru: http://gtr.infinite.net.au/lw_gtr_32_servi...vice_manual.zip
Not sure how long I can keep it available as it will depend on bandwidth. If others want to host mirrors, that would be great.
Let me know if you find any mistakes and I will try and fix them ASAP and reupload.
Cheers,
Lucien.
https://www.sau.com.au/forums/topic/68078-improved-r32-gt-r-workshop-manual/
  • Replies 42
is there any software around to traslate the picture to text? like you can do if you scan a document.
The problem is that, unfortunately, the manual was scanned as a series of images rather than using Optical Character Recognition (OCR) which would have made all the text portions appear as just that, text. As a side bonus, that would mean the text is searchable, selectable, copyable, etc etc.
I just tested exporting the PDF to image and running it through some OCR software. It seems to work OK, but will take a considerable amount of time to process. I will have a fiddle and see what I can do.
Richiarid :D No problems.
Lucien.
Hi Guys,
Your all very welcome. I hope you find it useful. Its nice to give something back (that people appreciate :D) to the community that's given me so much :grouphug:
Anyhoo, after trying to latest version of OmniPage (and OCR package) it seems it can import directly from PDF. I have experimented with it a little and it will still be quite an effort to swap it over from images to text, but give me a little time and I will see what I can do.
Lucien.
nice job matey....... it has help me out a hell of alot with my rb conversion in my 66 gt........ much appreciated .... good to see some decent people out there!
cheers.... :D
Ok,
I have spent the better part of the day trying to process the workshop manual with OmniPage. I have managed to get 100 pages done (so approximately 1/8th of the manual):
I would be interested to see if people think having text and images (rather than just a series of images) is useful -- ie. the text is now fully searchable. If you have a minute, feel free to download the 100 page "sample" and have a play with it. If people think its worthwhile, I will keep going and try and do the lot.
Sample is here (~9.5Mb): http://ugbox.net/~lance/OCAU/lw/R32_WM_Rev2_Test.zip
