Hi All,
I have been trying to make some improvements to the R32 GT-R Workshop Manual PDF that's floating around as I find its pretty unusable in digital form.
Anyway, after a couple of hours work I give you the improved workshop manual with rather complete bookmarks (make sure you open the bookmark tab in Acrobat) :D
Download the Zipped PDF (~21Mb)
Mirror by Amaru: http://gtr.infinite.net.au/lw_gtr_32_servi...vice_manual.zip
Not sure how long I can keep it available as it will depend on bandwidth. If others want to host mirrors, that would be great.
Let me know if you find any mistakes and I will try and fix them ASAP and reupload.
Cheers,
Lucien.
https://www.sau.com.au/forums/topic/68078-improved-r32-gt-r-workshop-manual/
  • Replies 42
is there any software around to traslate the picture to text? like you can do if you scan a document.
The problem is that, unfortunately, the manual was scanned as a series of images rather than using Optical Character Recognition (OCR) which would have made all the text portions appear as just that, text. As a side bonus, that would mean the text is searchable, selectable, copyable, etc etc.
I just tested exporting the PDF to image and running it through some OCR software. It seems to work OK, but will take a considerable amount of time to process. I will have a fiddle and see what I can do.
Richiarid :D No problems.
Lucien.
Hi Guys,
Your all very welcome. I hope you find it useful. Its nice to give something back (that people appreciate :D) to the community that's given me so much :grouphug:
Anyhoo, after trying to latest version of OmniPage (and OCR package) it seems it can import directly from PDF. I have experimented with it a little and it will still be quite an effort to swap it over from images to text, but give me a little time and I will see what I can do.
Lucien.
nice job matey....... it has help me out a hell of alot with my rb conversion in my 66 gt........ much appreciated .... good to see some decent people out there!
cheers.... :D
Ok,
I have spent the better part of the day trying to process the workshop manual with OmniPage. I have managed to get 100 pages done (so approximately 1/8th of the manual):
I would be interested to see if people think having text and images (rather than just a series of images) is useful -- ie. the text is now fully searchable. If you have a minute, feel free to download the 100 page "sample" and have a play with it. If people think its worthwhile, I will keep going and try and do the lot.
Sample is here (~9.5Mb): http://ugbox.net/~lance/OCAU/lw/R32_WM_Rev2_Test.zip
    • I ❤️ Matty I would like to thank Matty for going out his way in securing me a OEM NC detachable hard top for the NC Matty, your worth your weight in gold, and I cannot say how much I really appreciate your outstanding help I'll get it colour matched once I pick it up sometime in Dec-Jan 😁
    • We have some genuine Japanese legally decommissioned car number plates now in stock 🙂 Add some legitimately obtained JDM style to your Skyline or other Japanese model, or simply as a garage/man cave decoration! About the 40mm hole: The Ministry of Land, Infrastructure & Transport in Japan recognised the popularity of keeping decommissioned plates among car enthusiasts and came up with a method to "destroy" (or render them unusable for street use) while still retaining their collectable/usable value for display etc.  We have 40mm hole covers available to cover the hole nicely with a Sakura motif, which are also available in white in (very!) limited quantities, however they frequently sell out. Please let me know if you're wanting one or more of these and I'll check availability. The Sakura motif covers are more common. https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set-su-7515 https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set https://www.oemsoko.co.jp/products/genuine-japanese-vehicle-number-plate-400mm-hole-cover *Please note that we can't obtain particular number or area name (eg: "Gunma 500 Fu ・86") if requested. All plates are provided as they become available after decommissioning.
    • Ah, fair enough. For the IAT, I'm using a legit GM sensor that was used on the car prior to my current build. I'll get another wideband and IAT ordered and follow up when they show up. Thanks for the help.
    • You shouldn't need to massively fatten up the mixtures for cold conditions. For one thing - 0°C is not that cold. For another, the Haltech will be using the IAT sensor to tell it how dense the air air, and calculate the correct amount of fuelling. Then the cold start enrichment is added as a % on top of that, so it should scale with the main fuelling. You might also doubt the IAT sensor at this time. You're not using one from an RB26 are you? Using a nice Bosch sensor or similar? Happens. Some wideband units take great pleasure in killing their sensors. Put another wideband in the tailpipe and compare. Or just swap the sensor to a brand new one and see.
    • Oh, my misunderstand. When the car was running, it sounded ok, but if I gave it any gas it wanted to die but caught itself afterwards. It's very different from how it was a couple months ago when it was warmer outside. The logs show that the AFRs are better during, what I assume, is warmup enrichment. Because it's cold, and air is more dense, should I work on the enrichment bit?
