okay here the story in short my car goes into rexy mode after a few minutes in cold start i have changed coil packs and all other obvious things!
sometimes will go away now iam really confussed today as the fact iam driving in rexy mode (missing a cylinder) then i turn the car off and start it agian and wat do u know fixes itself????
iam really confussed cause it goes away and then comes back but once it gets normal its fine
Has ne1 experienced this????
https://www.sau.com.au/forums/topic/68086-missing-r32-xperts-required/
I'm in the same boat as you. ;)
What did you replace your coilpacks with? (Spitfires or secondhand stockers?) I'd be looking for hairline fractures.
I haven't checked my coilpacks but I've had UAS and Grey Imports report back with nothing. I have a feeling it could be some of my injectors playing up but I had them flow tested and cleaned about 5,000km's ago...
well firstly i replaced with brand new nissan coil pack haha they not cheap the impedence on them is also good!!!!!
iam starting to think faulty injector but i dunno
cause wen it is warming up ie i leave for ten minutes its will start missing and then go into rExy mode!
its an idle problem in the first ten minutes of driving but then becomes all sweet. but its intermitant!!!!
the engine is reasonably to new had the thing rebuilt about 8 months ago
well another thing you should maybe do is ,, take the oil cap off,, and if oil spurts out it could be ur piston rings,, thats what happend to my car..  :ufo:
sorry iam intrested in ur theory BUt wouldnt this be more of a constatnt problem mine is only intermittant and mainly on idle wen sitting for a while and after the car reaches 75-80 deg norm operating temp then it all comes good???
thanks
I agree with GTS500, I had the same trouble.
I replaced my coils with Splitfires
It ended up being the Ignition Module. Its a common problem and isn't an expensive one to fix.
well iam liking ur nolledge here
i think i will try ignition module altho i rang up to buy a new one and they want $800 bloody nissan parts.
u say not xpensive how then to do i dunno bout wrecker parts as with my luck it will **** up in a month or two??
help appreciated
My suggestions......do a leak down test, that will rule out mechanical issues. And get the injectors cleaned and flow checked. Have you cleaned the AFM lately? If not, give it a clean with some brake cleaner. If none of those cure, it I suggest getting a loan (or buy) one of Impakt's copy Consults, the diagnosis available will save you some money otherwise wasted on buying unnecessary parts.:)
    • I ❤️ Matty I would like to thank Matty for going out his way in securing me a OEM NC detachable hard top for the NC Matty, your worth your weight in gold, and I cannot say how much I really appreciate your outstanding help I'll get it colour matched once I pick it up sometime in Dec-Jan 😁
    • We have some genuine Japanese legally decommissioned car number plates now in stock 🙂 Add some legitimately obtained JDM style to your Skyline or other Japanese model, or simply as a garage/man cave decoration! About the 40mm hole: The Ministry of Land, Infrastructure & Transport in Japan recognised the popularity of keeping decommissioned plates among car enthusiasts and came up with a method to "destroy" (or render them unusable for street use) while still retaining their collectable/usable value for display etc.  We have 40mm hole covers available to cover the hole nicely with a Sakura motif, which are also available in white in (very!) limited quantities, however they frequently sell out. Please let me know if you're wanting one or more of these and I'll check availability. The Sakura motif covers are more common. https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set-su-7515 https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set https://www.oemsoko.co.jp/products/genuine-japanese-vehicle-number-plate-400mm-hole-cover *Please note that we can't obtain particular number or area name (eg: "Gunma 500 Fu ・86") if requested. All plates are provided as they become available after decommissioning.
    • Ah, fair enough. For the IAT, I'm using a legit GM sensor that was used on the car prior to my current build. I'll get another wideband and IAT ordered and follow up when they show up. Thanks for the help.
    • You shouldn't need to massively fatten up the mixtures for cold conditions. For one thing - 0°C is not that cold. For another, the Haltech will be using the IAT sensor to tell it how dense the air air, and calculate the correct amount of fuelling. Then the cold start enrichment is added as a % on top of that, so it should scale with the main fuelling. You might also doubt the IAT sensor at this time. You're not using one from an RB26 are you? Using a nice Bosch sensor or similar? Happens. Some wideband units take great pleasure in killing their sensors. Put another wideband in the tailpipe and compare. Or just swap the sensor to a brand new one and see.
    • Oh, my misunderstand. When the car was running, it sounded ok, but if I gave it any gas it wanted to die but caught itself afterwards. It's very different from how it was a couple months ago when it was warmer outside. The logs show that the AFRs are better during, what I assume, is warmup enrichment. Because it's cold, and air is more dense, should I work on the enrichment bit?
