We'll I must admit that I've never heard of them, so I can't say that they are good or not. I think the choice as to whether to chip the car or go for proper engine management is where do you want the car to end up, as far as power output.
Chips are really only good if your going to keep everything else in the car relatively factory, even by adding a blow-off can disrupt a non-tunable computer. And having read the PDF advertisement (propaganda), I would be hard pressed to believe there claimed power/torque improvement without the obligatory airfilter and exhaust changes.
If you are planning on saving for a Power FC, do not discount other computers on the market which have the similar plug'n'play capability. Both Wolf and MicroTech have plug'n'play units for the R33 GTS-t, and while I can only talk based on knowledge about the Wolf, I have one, they are very cost competitive versus the Power FC.
Anyway I'm not about to start WWIII in the engine managment debate, just choose one according to the level you want the car to achieve.
See'ya:burnout:
https://www.sau.com.au/forums/topic/6810-r33-powerchip/#findComment-100809
I believe the power increase is possible as it is only 15% increase from 187 to 215kw. Even after drivetrain loss, at least you'll feel it in the mid range. With air & exhaust change, it would even felt better.
I had one of their chip in my previous car, a 93 Mitsu Galant SE Hatchback with 4G63 2.0 SOHC engine (????) No one outside australia ever known a 4G63 2.0 SOHC, as everywhere else in the world seems to have DOHC. That is the reason why I could not get any aftermarket parts from big names like Apexi/Greddy/HKS, etc. Even air filter is not available until our local Unifilter "came to the rescue".
Anyway, with stock exhaust & Unifilter panel foam air filter, I noticed difference in mid range power (It was N/A engine). I enjoyed it for a while. Sadly the car has to go, because I find it's getting harder to find aftermarket mods for such a rare car.
A$900 seems a fair deal if u dont want to spend $2000+ for powerFC or any other aftermarket chips which seems to be around $1500 mark. With extra pocket change, you could get exhaust/pod filter which would be performance bargain, as long as you're not too ambitious on the kw gain.
PS: I am not afiliated with powerchip, just expressing my own experience with them. Great cust service too, they gave me a V8 SS Commonwh*res (yeah, yeah, I know wat u guys feelin) as courtesy car for the day.
Note: For those who has auto skylines, I'm finding out if the chip works with auto gearbox. If it does, then maybe this is one option to upgrade your ECU, as powerFC and most chips alike dont work with auto R33 (according to HPI magazine). I'll post updates once I found out from them. I am sure it will work, as their V8 SS is an auto & it has powerchip in it.
https://www.sau.com.au/forums/topic/6810-r33-powerchip/#findComment-100913
What up peoples,
Whats the go with the Nengun site, they have power fc's cheap. like secondhand power fc for R33 with boost controller pack and greddy speed cut thingo as well as the controller for $1600 delivered. now that sounds bargainish to me, they also have power fc with hand controller only (second hand) $1300.
what do you think thats not far off from the $900 for the chip aspecially cos they also have the power fc with no controller for about $1000
ahh too many choices.
scratcha later
RiaZ
https://www.sau.com.au/forums/topic/6810-r33-powerchip/#findComment-101208
It's impossible to build a one off chip to suit all R33's coz everycar is diff. Tuning should only be done on a Dyno in real time where the tuner can see your A/F ratio and power curve. For $660 fitted and tuned I bought an Apexi SAFC, it allows adjustment of the A/F ratio with good results, 40rwkw in the midrange and 20rwkw peakpower improvements.
https://www.sau.com.au/forums/topic/6810-r33-powerchip/#findComment-101671
A chip is a "one stop" replacement for like a standard car or one with just a better exhaust or intake. I doubt it could give you the best out of an engine after you have put on a few mods. It will probably give you a reasonable 10-20% gain if your car is pretty standard which might be enough for some people.
You're better off with a fully adjustable ECU, which can be programmed, give you realtime response curves, etc. Then you can go mad and get a laptop and plug in and start programming fast and furious style from incar to give you absolute control. Too cool! Probably not a cheap approach though
Would be interested in people's experience with this full on approach? :burnout:
https://www.sau.com.au/forums/topic/6810-r33-powerchip/#findComment-101742
I agree with you predator666, however this path would probably suit those who got manual gearboxes, as powerFC, eManage, Microtech, MRT and the likes all only works with manual cars.
If you have an automatic transmission like some of us do, it may require another approach like this replacement chip. Powerchip said that their chip will work with automatic transmission cars. It confirms as their previous courtesy car was an auto V8 Commie (see my previous post) with Powerchip installed. Here is their reply to me:
Hi Rianto,
Great to hear of your new car. They are great.
If you are running 98 octane fuel, then I recommend the Gold 98 Powerchip. This
is our best one and will give you the most performance gain. The Gold and the Gold 98 are the same price of $990, fully installed.
There is no reason that we cannot do automatic gearboxes.
Unfortunately, in the past, we have had many bad experiences with group
purchase's. We do not offer discounts on any of our products for group
purchases
Kind Regards,
Ryan Naylor
Power Consultant
Powerchip Pty Ltd - Australia's leading performance chip company. P + 613 9681 6888 F + 613 9681 6777 RNaylor@powerchipgroup.com www.powerchipgroup.com
Too bad they won't do any group purchase.
You can contact them on the number above, they're in Melbourne but will do interstate delivery and installation at approved installer australia-wide.
https://www.sau.com.au/forums/topic/6810-r33-powerchip/#findComment-102932
    • Hi all,   long time listener, first time caller   i was wondering if anyone can help me identify a transistor on the climate control unit board that decided to fry itself   I've circled it in the attached photo   any help would be appreciated
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
