hey guys after some help about my new TT...
i just bought an apexi turbo timer second hand from the forums. its a good little unit as it has just the basic essentials without the extra crao i don't need
does anyone have this particular TT or the instructions for it? (see pic)
it has 2 plugs to connect it to the car...
they seem to look like you would find a plug in the car, open that one, and splice this unit in between the old plug by connecting these plugs to the opened plug on the car.
where can i find the plug to connect it?
and also, if anyone has this aprticular unit, what wires are for what and is it compatible with my alarm or do i have to wire a relay?
cheers,
Warren.
https://www.sau.com.au/forums/topic/68108-who-has-an-apexi-tt-help-me/
if its not there tap into the ignition wires from behind where you put the key in
you will more than likely have to run a relay as the alarm will either not arm when the cars on or it will go off when it is armed
    • yeah, there's a country that recently started importing Skylines, I blame them.
    • I don't have a printer, but could at least attempt to make a printable model.
