Track whores!! - show us your bonnet restraint!
Hi guys, having been off work for the last 2 days from illness, and generally going mad watching day time TV, I sat down and devised what I think is a good secondary bonnet restraint for track days.
Basically, one end is hooked into the bonnet in holes next to the bonnet latch. The wire is secured through two washers, one of which has a few holes drilled through. The wire is threaded through as in the pics, and a bolt holds the two washers together. The end that attaches to the bonnet is secured with a wing nut, to aid getting the thing on and off.
The other end of the strap is configured in the same manner, only it is secured by a nut rather than a wing nut. This end is hooked onto one of your tow hooks via a carabena.
If anyone wants them I can supply without the carabena for $15 or so :(
Tell me what you think or show me what you've got!
Cheers
For those of us who still have no clue how this works and for what.. can you explain further? :)
Basically, when you hit the track, you are almost always required to have a secondary bonnet restraint apart from your ordinary latch.
Bonnet pins are an option, but for a street car they are illegal (protrusions) and defectable.
The restraints I was previously using were difficult to use, so I thought this was a better solution.
When you open your bonnet, there are a series of holes on either side of the bonnet latch. For this restraint, you undo the end with the wing nut, open the end of the hook and thread it through two of these holes. The reassemble through the washer and fasten down the cable with the wing nut.
When you close the bonnet, the restraint will drop down in front of the radiator, then you just latch the other end of the restraint to one of the tow hooks using the carabena
Too easy :(
Here, get this up ya's, impatient buggers.
I used nylon coated steel wire rope of about 5 mm diameter using bulldog clamps on each loop. Then a stainless crab to join.
I will be installing the aerocatches when Nelly isn't looking ....shhh :P
That's what I was running, but found that my bonnet wouldn't shut properly... and basically the one denham made for my car was too short - so to get in there and do it up you needed hands of a gypsie / pikie...
ps show us the turb's side!!
Ronin 09: The restraints that Geoff has shown you have been used on Archie's silver R32 GTR and it opened and shut fine. You do need to leave a little slack to reach in. The restaints are not there to stop the bonnet opening, they are only ment to stop the bonnet from hitting the windscreen and covering your vision. So having the restaints long enough to open the bonnet about 40cm should be perfect.
Strange but true- we've gotten away with using one of those webbed belts you pick up at Just Jeans for about 10 bucks :D
hehehe works on rental cars too.
i used a piece of boring old hemp rope at bathurst a few years back too
It doesn't have to be sexy, hell it may not even have to work....just has to be there.
  • 3 weeks later...
Hey , i hadnt seen these photos:)
The twin setup looks good, see that tape came in handy:thumbsup:
... and the new GTR bar... fark it you were so close to getting the thing to the track with grunt, susp, cooling and borrowed rubber:)
Will you still be around for Sandown in June, only i wont have any spare rubber to lend you, im using it like its going out of style:(
And who is that Malboro esq, stunning hunk of man meat....he must do all right with the girls:)
Still not getting time for the car but I do intend to be here in June. May even have the wheels and rubber by then but a big thanks for the offer for Calder, just wish I'd got there.
That bar has come off to remake the mould and my new/replacement one is supposed to be Kevlar, with a vented Kevlar bonnet and maybe an undertray and splitter with Kevlar guards coming later. Mine is meant to be the demo car, but the guy making them was in a prang on the weekend where he broke his collarbone so a bit of a wait on the stuff.
As for the marlboro man....last sighted at Sandown grinning from ear to ear.
    • I used the radium thing, makes the whole parallel assembly a lot more compact compared to any other way of doing it
    • Racetronix also sells those ethanol content sensor bypass blocks. Adapter, Flex-Fuel E85 Sensor High-Flow Bypass, In-line No Sensor (ADF-FLEX-NS): Adapters - Flex Fuel | Racetronix Ethanol content sensor are originally designed to be on the feed line. These bypass blocks are meant to be ran in the feed line and not return. The continental ethanol content sensors have a 3/8" ID and not 5/16". This is why they are ran on the return line directly in conjunction with a low threshold sampling value VS in the feed with one of these blocks.    Haha we think alike, I used both original feed/return for 8AN feed, and one of the Hicas lines as a 6AN return. I also capped off and left the other Hicas line as a spare.
    • Interesting, I haven't read about the issue with oil getting into the speedo in the cluster before. I'll have to take more notice with mine. The speedo on my R32's when I've run factory diff and tyre size have never been accurate as far as I can remember. The non Type-M GTS-t did come with 15" 5 stud wheels and smaller brakes, but that's less than 5% of them.
    • Good to hear the condenser you picked up off my brother worked all good. Do you think there could be an issue with your AC compressor itself or the clutch on it then? I don't know a lot about them so I can't really help but keen to hear what it ends up being. Keep the build thread going man, it's nice to look back on over time.
    • This is a story of my life things, I learned eventually (thanks to someone calling me out) that my enthusiasm for discussing and sharing ideas that it came across as arrogance and I'm like... WTF?!    One thing I'm pretty sure I justifiably pride myself on is knowing that everyone will have things they can teach you, and you're always going to find out that something you think you know turns out wrong - you just don't know what it is until you get there.   Just the bursting enthusiasm that comes with ADHD when you hit something that gives you dopamine dumps can come across like you think everyone else is wrong or don't matter. But yeah, I'm a software engineer by trade and also do tuning in weekends and 100% have long had a reputation for  quickly making connections when resolving problems or forming solutions that I've sometimes had to take people form a long walk from start to end to explain how I ended up where I did when it's seemed "too simple" when I've stated my initial case, and had the "WTF" type reaction when they've realised how much was actually considered haha.   My reward is that I get all the curly problems thrown at me.
