If you want to spend $25 a litre...go Redline
If you are strapped for cash, go Fuchs, about $35 for 4 litres (GX 80 I think...have to look in the shed)
I also use Castrol Fully Synthetic diff oil...expensive but worth every penny...2 even black lines all the way
What ever you do, stay well away from Nulon oil additives, better yet, stay away from additives period.
https://www.sau.com.au/forums/topic/68169-best-gearbox-oil/#findComment-1263389
  • 6 months later...
Hi,
What's one of the better gearbox oils to use on a '96 GTS-T with around 80k on the clock. I was told Motul Gear FF by Merc. Motorsport.
Thanks.
I used Royal Purple Synthetic with some Slick 50. I was happy with it. Changed to Kendall Synthetic and Slick 50. Unbelievable inprovement. I have 156,000km's on car . I was abit worried about synchro's till the change to Kendall.Couldn't recommend Kendall highly enough
https://www.sau.com.au/forums/topic/68169-best-gearbox-oil/#findComment-1614536
I've got redline oil in the gearbox and diff and they seem decent, although I haven't tried other oils to compare against (exluding the standard oil) :)
I was always under the impression that the standard diff unit (that actually controls the 1 - 1.5 ability of the diff) in a R33 diff is a sealed unit within the diff, so no matter what oil you use it won't affect it's ability to lock-up or not?
https://www.sau.com.au/forums/topic/68169-best-gearbox-oil/#findComment-1614576
General recommendation from Shell Aust oil techs is to run a synthetic in any high power/high load application. While you get similar viscosity ratings to mineral gear oils, their lubricating qualities are different, as are their abilities to resist degradation through shearing of the molecular structure.
It seems that most synthetics are "slipperier" and this helps the shift quality even under normal daily driver usage. FWIW, I understand that most/all heavy duty truck manufacturers recommend synthetics due to their qualities and vastly increased service intervals.
So paying the extra $$ should have payoffs. I don't personally think the brand is as important as the formulation (ie synthetic or mineral)
Regarding the oil additives comment, I've recently used a product called Molybond to see how it worked on a possibly worn synchro. The shift quality has improved out of sight, but still assessing whether a rebuild is required. Nulon's product is different, but should deliver the benefits they advertise. A mate has used it with some success. Nulon's packaging specifically states not for use with ester based synthetic oils.
cheers
Dale
https://www.sau.com.au/forums/topic/68169-best-gearbox-oil/#findComment-1614881
    • Not R7R. Meant to type R&R, obviously enough.
    • Bugger "making it look stock". I put one conventional internally fused Hella relay behind each globe. I just pulled the plugs off the back of the globes and built new loom segments with male and female plug parts to match up to the original loom and the globe, and used the original power wires to each globe coming from the switch through the original loom plug to trigger the relays. Ran a big fat (also separately fused) power wire across the front of the car to feed all the relays. It's as ugly as f**k, but it is wedged down between the headlight and battery on the RHS and the airbox and headlight on the LHS, and no-one ever looks in my engine bay, and on the odd occasion that they do I simply give no f**ks for what they think. Fully reversible - not that you'd ever want to. For f**k's sake. It's a Skyline. They made million of the bloody things. We've been crashing them into roadside furniture for 30 years now. There is a negative side effect to putting relays on the headlights. The coil current is too little to properly clean the contacts in the switches and they get blacked up and you have to open them up every couple of years and clean them manually. I have 25 years of experience on this point.
    • I was poking through the R34 wiring diagrams vs R33 and noticed that the R34 has proper headlight relays while the R33 is like the R32 and sends full headlight power through the headlight switch. I'm not afraid of wiring but I really would like to do this in a way that looks OEM (clipping into open positions on the OEM relay box) and also unlike the factory wiring which interlocks the high beam and low beam on the halogen series 1 GTR headlights I want to make it such that turning on the high beams keeps the low beams on as well. Any advice on how to locate the specific connectors + crimp terminals + relays I need? I was thinking one NO relay for low beams and another for combined high + low running off the factory high beam headlight connector. I don't really want to splice into a crusty old probably discontinued factory harness so fully reversible is my goal here.
    • Pretty sure they run the same engine as the Q50 hybrid which specifies 95 RON.  I ran 98 in mine for a while, but it made no difference in performance or economy, so I have been using 95 for the last few years.  I have never hit 6.0L/100km, but have returned mid to high 6 on the highway.  Being a hybrid, fuel economy is a lot more dependant on how you drive it.  At 110km/h, mine never goes into EV mode on the highway, so returns closer to 7.5L/100. urban driving can return low 8s if you are careful or over 10 if you are a bit more enthusiastic on the throttle.
    • About a quarter of what you want to do. It's only R7R, not R&dismantle&replaceparts&reassemble&R. ? It is stock. I already told you, you will NOT have broken those. It's f**king 4th gear for Christ's sake. You just chipped the teeth off.
