i hate to bring up an old thread, especially one that already has SOO much info in it. i just cant be 100% sure im doing the right thing. and wouldnt want to go ahead without checking :D
is that ok to do on an RB20 ?
nothing blocked off, just taking out line that was there and plumbing it through the can ?
Edited by thrtytwo
  • Replies 160
Think about what and where the oil is going... you would be catching the crossover between the breathers... so it would be 50% or a standard setup. I won't say it won't work... it might, I just don't think it would really be much use (especialy for the time, effort and money put in)
block off the ecv, and put the catch can on the other side (leave it plumbed to the I/C). 100% legal, better idling...
Of course, I have yet to do this...
to be honets i dont know what any of the pipes are, this was just the idea i got from what ppl were saying :D and a few pics of RB25s
hate to be a painb, rekon you could whip up a diagram in paint or summin :) ?
pwetty pweese *pouts*
Edited by thrtytwo
Hi Guys,
I am going to put on a 100% atmo catch can and have the filter installed remotely somewhere hidden with extra piping...will this still work?
Also from my sig you can see the pipe connecting the 2 PCV's is altered with an exit hose between them which at present just goes to the firewall and does nothing. Can I replace this pipe with one connected to the catch can? and not have it connected directly to the LHS PCV?
Cheers,
JB
  • 3 months later...
  thrtytwo said:
still wondering how to plumb to RB20. can sum1 post a pic of your setup with a greddy style can, or cusco, as long as it only has 2 inlet/oulets and not 3.
Yeah, i want to know as well.......... :P
  • 1 year later...
ecv?which side is his? inlet or exhuast rocker cover side?
can some post a picture up with this setup..
this sounds like the setup im going to do...
more info on his setup would b great..thanks
  • 3 weeks later...
hey guys,
i've just installed a catch can on my RB20DET, and did it the wrong way the first time.
the car was pouring out smoke which smelt like burnt oil, so i read up on this topic and followed SydneyKid's 50% plumback diagram:
i have a couple symptoms though:
the smoke pouring out the exhaust has stopped, but it still seems to have a very slight smell of burnt oil? i'm thinking maybe it's burning off the last bits from the previous installation?
i also noticed a strange ticking type sound which seems to be coming from the plenum area. the noise stops if i squeeze the hose coming from the plenum enough to stop the flow of air.
i've got a drift oil catch can, with 2 top hose fittings, and 1 lower.
i've used the lower one for the plenum, the top ones for the rocker cover (with the original "u" shaped one intact), and the return line for the intake pipe has been blocked.
does anyone have an idea?
Sydneykid where are you?!
thanks,
dave.
Edited by dmr
  • 1 month later...
would it make a difference if i block the line going from the rocker cover to the inlet manifold and then run the other 2 lines to the catch can and plumb them back to the turbo inlet or should i run the manifold pipe through the catch can as well and then a return to the manifold?
  • 7 months later...
  MintR33 said:
Thats ok if you just want to remove oil any oil from entering the intercooler but you should ideally plumb the PCV valve line to the catch can too.
I haven't found a way to do it with a catch can that only has 2 ports. The diagram I've seen is for a RB20 and I've read where people say it works differently between the 2.
  MintR33 said:
Ah, ok. Thanks! So that would mean that I'd have to plug up the cam cover-to-intake ports? There's a post that says it would cause a boost leak if left there (I think).
This is what I was talking about doing: http://www.skylinesaustralia.com/forums/in...t&p=4337772
But are PCV valves specific? Like, if I get an inline one, will it flow/move the same amount of vapors as the thicker one made for this engine?
Edited by Neejay
  • 3 weeks later...
I'd like to revive this dead thread cause i am confused as hell right now
this is how i have mine hooked up (I got it this way from japan)
So i'm thinking about running the atmospheric setup shown on in this thread and putting one of these types of filters between the PCV and the intake manifold, but the one thing that is leaving me in doubt is that some people claim that the atmospheric setup creates a vacuum leak in the system.... So what is it, will it or wont it create a leak?
i used to use one of those filters on my old car between the pcv and the IM and it worked great, collected allot of oil
Opinions?
Opinions?
I never got a response, so I'm going to run mine similar to yours, but I'll run 2 hoses separately from the valve covers -> T fitting as close as possible to the catch can -> into the catch can + stainless-steel scrubbing -> and out to the intake pipe. I think I'm going to just cap off the PCV valve and the intake manifold nipple.
Edited by Neejay
the way your describing it makes the catch can sound kinda of pointless really but maybe i'm understanding it wrong
and what benefit would capping the pcv valve rather than than putting a filter like i described have? the way i see it, the pcv valve is there for a reason isnt it?
Edited by MoogLe
No, it's basically like what you currently have, but instead of the hose going to the other valve cover, it will go straight towards the catch can, then BOTH valve hoses will combine via T fitting right before going into the catch can.
A filter instead of the PCV valve cap will cause fumes and look less clean, in my opinion. I may try to find a plug and just take out the PCV valve all together.
EDIT: If you have a 2nd picture, I can't see it. What filter thing are you talking about?
Edited by Neejay
    • I can ship Nismo floor mats to you: https://www.oemsoko.co.jp/products/nismo-floor-mats-for-skyline-r33-bcnr33-stagea-wgnc34?_pos=1&_sid=9278c1467&_ss=r
    • Here's the link: https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6642/misc/G49?frame_no=WGNC34-137122 What you think about it? The same product i found on nengun: https://www.nengun.com/oem/parts/40567/MiPwn5qAMfCfmpxHNDnwn5q9MDAx8J-QiW9sZC1qcC0xMTAtRzQ5LS0wMDE/Floor+Carpet+%2F+Mat+2/0688339eba149c19 Bot i have spoken to 😅 ensured me, that mats are 100% original, oem product. I have my doubts. I also heard what you mentioned, that nengun often offers items that are actual not available... On the other hand mats i found on japanese yahoo or ebay are in poor condition and still quite expensive so i'd rather wait for some better offers. My location - Poland. We literaly don't have ANY market for used Stagea parts so need to search outside Europe.
    • You can’t see much on the other side as the lcd is there I don’t think it’s the same as the m33 beside it as the markings on top is not the same was hoping someone had a good quality photo or if they just happened to have the unit in hand, quickly take the cover off and take a photo to clearly show the marking on top to identify the diode   the unit is currently with an electronics repair shop so I can’t take another photo at the moment hopefully they are smart enough to know if it’s a zener diode or not
    • I'd be very surprised if you can buy new OEM mats. But if you can, I want some too!  Do you have links to the variations you found? Also, where are you located? I found that Nengun is happy to list items to purchase but when you do buy them you'll get an email that it's actually discontinued. As far as I know the variations in floor mats are different colour schemes as well as automatic and manual having a slightly different shape. The automatic ones fit into a manual car without issues, but I think you'd have trouble fitting the other way around. I have photos that show the shape difference if you care. FWIW I bought sets of used floor mats in decent condition at yahoo auctions.
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
