  • Replies 80
Hey is that your carerra ...and gtrs dislikes  you
Bring it on bitch .lol
ill make your porche look like a charade , even over 200 k
If you’re going to insult me you juvenile piece of shit, atleast spell it right. It’s Porsche.
You will make the Porsche look like a charade? I’m a person who likes a good punt, put your money where your mouth is fool, you’ll be put in your place out at Queensland Raceway, where the real men race. None of this straight-line rubbish.
Ok ..when and where
On any race track ,if you feel you can dad ..
If you win ill shake your hand ,so you better have some practice and to just let you know i was in the porsche club in sydney and had many track days at Oran park and eastern creek with my skyline againts the gt4 and many others ..
i must admitt the porschers do go well and handle awsome ,but not many kept up with me and only a coulple beat me ..so you got what it takes ,bring it on
The GT4 is a video game on the playstation :D... The GT2 or even 3 is a porsche, you can buy a GT2 in GT4 but its called a ruf... so confusing I know.
If josh is willling to race, which im sure he will be, im sure we can get a decent crowd out there to watch...
Hell, i'll even organise it...
Ok ..when and where
Specs on your car? So I know if I have "what it takes". Either way I'm always up for some fun
Thread posted...
Kel, come along if your here for this :)
Heh heh, I think I'll have to- it looks far more entertaining than the boring stuff we do in NSW :D
I'd be in for an Anzac cruise too - was really only looking to turn up to anything you guys might have already had organised?
Us??? Organised???  BUWAHAHAHAHAHAHAHAHAHA
bahahhahahhahahha even when we organise stuff it usually ends up being different, but id be coming to this as it should be quite a day!
HAHAHA you clown, ive driven this car and let me just say good luck, you will need it
Well you have not driven mine ...
My car has been tuned in japan By a jap mechanic ,which are friends of mine ,when i visit for certain events.
Ill shall not say too much as my car is a full race spec and 800 horses
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
