Hey Guys,
89 GTST.
I am worried my turbo is on it's way out. I only got the car from japan on Saturday, so I haven't even had it a week yet. :rofl:
The turbo( or so I think) has had a small whistle in it that increases as you build boost. The whistle has gradually gotten louder over the past few days. I have searched and it seems that most people think the turbo is about to throw the wheel, or it's an exhuast leak.
I also have idleing problems -> http://www.skylinesaustralia.com/forums/sh...548#post1265548 <- don't know if it would be related or not?
What is my best plan of attack? How can I find an exhuast leak? Should I pull the turbo out and check it? What do I look for?
Anyone have a step by step guide to getting the turbo out the quickest/easiest way? Otherwise I will just work it out myself I guess!
Thanks guys
Chris
https://www.sau.com.au/forums/topic/68249-dead-turbo-exhaust-leak/
I had the same prob and found that it was the gasket between the turbo and manifold. You can pick them up for $10 but it is a prick to replace.
To check, When your car is cool. Start her up and feel around the turbo for air poping out(you may need to take the turbo guard off for this) and also look for carbon build up on the inside of the guard.
Hey guys,
It was the BOV! It blew part of the gasket away (had to take it off to see) so it was a boost leak...it's now back to the way it was when I got it (which is still there, but only a little)
I am guessing it will be totally fixed when I get the replacement pipe to ditch the BOV. Dam ricey Blitz BOV...haha
Cheers Guys
    • looking forward to your t56 swap man its a game changer if it works!
    • So, when are you trying the new GR86 or BRZ?
    • Uncle Duncan Yeap, FI Interchiller  Works well, normal IAT's cruising with the WTA only went from 50°c+ to 25-30°c with the interchiller  Before, when on it hard, the IAT would see 80-90°c, now, the highest has been was around 38°c IIRC IAT is measured under the blower hat I recommend it for the street or strip where your only on it hard for 10 or so seconds, but it wouldn't be efficient for sustained track use as it would heat soak from the AC turning off or whatever it does during WOT to protect the compressor It really needs the AC running for it to not heat soak and keep the WTA coolant chilled My WTA coolant temps when just cruising is around 2°c
    • Hey Mark...sorry to interrupt your career change to hair dressing... but...did you ever fit the interchiller to the commodore, and if so how was it? And, who made it?
    • I've been pondering this, I really enjoy the convertible thing, for me, it's like riding a motorbike, without all the issue of riding a motorbike, mainly, my old sore arthritic joints getting beaten up, and, being able to do it in shorts and a T-shirt and not needing a helmet and all the other gear required, especially like wearing jackets and pants in the summer, or needing 6 layers of cloths in the winter, or not having wet weather gear handy when your 100km away from home on the bike when it decides to start raining As for the hard top and its Coupe look, whilst I do lose all that open top feeling that I really enjoy, from my experience with the NB with a detachable hard top, the cabin is a much nicer place to be, the difference in noise for one, a hard top quietens down the interior, alot, with the soft top up or down it's pretty noisy, which, after 5 or so hours, can get tiring But, as you stated, the detachable hard top totally changes the look of the car, in a really good way, and for me, the look of a detachable hard top is so much better than the PRHT which looks more like a after thought with its weird bulbous rear roof line For me, the minimal effort of putting in on, or storing it after removing it, is well worth the time and effort for the look alone And yes, I'm sure the next owner will be grateful for it as well.......
