I will be starting to sell my car in approx 2-4 weeks time
Most of you know the car, but for those that do not it is a
95 mod R33 GTST
Manual
400hp hiflo ball bearing turbo only run at 7-8 PSI
Custom Ford blueprint paintwork
Full DP Sports body kit
Zeal alloy body coil overs
17x9 and 17x8 Dewalt 3 peice Japanese wheels
235/45/17 front 80%, 255/40/17 rear 100% new.
3 1/2 inch turbo back exhaust
Alpine stereo, Focal spilts, Rockford amp
And a few more extra's, Momo steering wheel, Nismo short shift, Bosch 910 fuel pump, nismo clear side indicators
I may except a part trade of a car upto $10000 like a Seca or Lancer 4 door or something for the wife.
Unsure of price yet, but approx $20,000 give or take a bit
It has approx $20,000 of extra if you bought them new.
So you are getting the car for free :(
If anyone is interested PM me
This is a old photo with my old wheels, has gold and polished rim 3 piece wheels now. (Has factory door mirrors not the Ganador door mirrors and no FMIC)
Thanks
Darrin
0404 075 314
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
