Due to some misfortune in the form of my turbo oil lines bursting in flames and oil leaking out causing oil starvation, my Turbo bearings are dead. Well atleast Im pretty sure they're dead, the car is not making power on the dyno and there's this high pitch screetching noise from the turbo at idle.
The turbo in question is a HKS 2535 so Im considering my options at the moment, Is it worthed to buy a new bearing cartridge? how much are they and where can I get them from? Or should I just throw this turbo in the bin and go source another one?
Ring your local turbo shop, is that Per4manz? The 2535 has pretty much a standard Garrett core, so it may be a easy swap job. For a pice comparison give GCG or Ray Hall a call.:)
Thanks SK
I'll do that soon, Is there like a model number for the garrett core Im looking for? or are they the same for most of its turbo range?
I think it's a GT25 core, but the turbo specialsits will know what is a 2535.:)
That scratching noise is probably the turbine hitting the compressor cover, I've had two bearing cartridges collapse in the space of weeks and both needed new bearings and front compressor wheels and needed to go to Garret to be balanced. I got a bit of deal done but you would be looking at close to $800 i figure.
Took a look at the turbo today
Bearings definitely dead, the blades would hardly spin
A lot of resistance and a lot of shaft play
I dont see it hitting the compressor cover though
If the blades is only slightly rubbing the compressor cover, would I need to change it? I cant see any physical damage
you'll probably also need to get a new thrust bearing... might as well get a new turbo because all that stuff adds up especially from shops that do it for you. I dont know of any shops that do balancing of the rotating assembly outside of the states, be sure to ask specifically how they balance the parts if you do decide to rebuild.
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
