OK its not as fast as the skyline... but i did drag a crummydore today.. and won :rofl: well if you count who was first off the line haha.
I got me a scooter :(
So ... what can we do to it??
Nos?
Change the exaust??
Neons?? (actually considering it hahahaha)
anyways, its a red Vmoto Milan.. very funky! I got it up to about 70km an hour today. Feels like your going alot faster though. Should beable to get it up to about 80km/hr. My new baby is tucked away nice and safe inside the house at night.
well here are some photos...
https://www.sau.com.au/forums/topic/68335-i-have-a-new-toy/
  • Replies 42
watch those things tho. My bro got one, brand new, and the engine died after two weeks. It might not be under warranty too because somewhere in the fine print it says that for the first 1000k's you cant do more than 50km hr and it needs a service @ 300km. If you just bought it new i wouldnt go 70 in it
https://www.sau.com.au/forums/topic/68335-i-have-a-new-toy/#findComment-1267552
theres a more blokey version costs about $400 on the road.
and to get it up to 110, u can get the pistons bored out and the cat drilled. Guy at work has had it done to one.
mmm not bad. problem is strapping a stock r33 turbo would be like strapping a t88 to a suzuki cupachino. :burnout:
https://www.sau.com.au/forums/topic/68335-i-have-a-new-toy/#findComment-1267897
Yeah ive read the small print, not allowed to full throtle before first service... but.. ahh.. new toy.. put it this way... u just get the keys to ur new skyline... "you cant go over 80".. of course you dont do that for the first few days. Ill behave myself! Today driving it i stayed about 50-55. Wont be long untill ive done 400km for first service though, already up to 180.
https://www.sau.com.au/forums/topic/68335-i-have-a-new-toy/#findComment-1268188
Might be a bit awkward in a couple of months time
hopefully i'll have some wheels by then. so kyles will get the car and i'll have to take the scooter to the choochoo station. seeing i only work 2 days shifts each week it works out fine.
oh and i mean the blokey version was an extra $400 on the road compared to kyles one, my bad.
https://www.sau.com.au/forums/topic/68335-i-have-a-new-toy/#findComment-1268708
Because of winter?
Well.. i figure .. each winter, we get less and less rain. And when it poors down, its only for 10 or so min..
I rode today in the rain. Was fine. Came home nice and dry. The bike wasnt much different either. Just had to be a bit more carefull :cheers:
https://www.sau.com.au/forums/topic/68335-i-have-a-new-toy/#findComment-1269040
Because of winter?
Yeah.
Just watch out for cars, they tend not to see bikes or just don't care
https://www.sau.com.au/forums/topic/68335-i-have-a-new-toy/#findComment-1269057
Yeah, in such a small vehicle, you've got zero road presence, and many drivers don't watch out for you.
I was looking at buying a peugot scooter before I got the line, but when I took one for a test drive and was nearly run over by a 4WD, I decided I needed something bigger :cheers:
https://www.sau.com.au/forums/topic/68335-i-have-a-new-toy/#findComment-1269064
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
