  • Replies 93
cat /dev/rnd > /dev/snd
I used linix for ages, though Debian (apt is the greatest loonix tool ever)...
Might install it on my old box as a "**** around" server, but I'd never go back to using it as a desktop.. Way too involved and time consuming trying to get everything windows-based to work :cheers:
https://www.sau.com.au/forums/topic/68336-damn-computers/#findComment-1267877
Yeah, well I was sick of windows crashing all the time and the 400 spyware/adware a month.
I don't think I can get spyware/adware anymore so that problem is solved. I still have a dual boot with XP running.
BTW, I still have a running copy of DOS 6.22, ALL Windows Versions, Redhat 7 and 9 and Fedora Core3.
you say....what the hell do you know about OS's
I'm the f$%ken OS MASTER.
Linux aint that bad. Especially this Fedora. It way outpowers windows in all ways and has less vulnerabilities. Plus I was being attacked by members of Andre NET every day. I had to run 4 firewalls just to stay alive. Now...no probs and I have a massive artilary at my disposal....so now I go to war.
https://www.sau.com.au/forums/topic/68336-damn-computers/#findComment-1268357
Are you new to computers?
1 x hardwire firewall/router
1 x XP install with personal firewall running and all non-essential services blocked (remember, DENY all and allow each port individually!)
1 x MS Anti Spyware
No problems.
Just use common sense. "Britneynaked.jpg..................pif" is still a pif. "Click here for free porn" is never free porn. Accepting files from people you dont know is stupid. Running an FTP/HTTP on common ports is asking to be pwned. Using MSN is asking to be pwned. Using IE in anything other than "Restriced Zones" is asking to be pwned. Etc.
For the casual hax0r, a loonix box with a default install is easier to hop into than a windows box :rofl: Hello plenty of installed services that are all open and left with default settings!
I'm interested to know how linux "outpowers" windows too, is this a tractor pulling contest? X Windows is slow and clunky and needs a 3Ghz machine to run anything more hardcore than KDE.
https://www.sau.com.au/forums/topic/68336-damn-computers/#findComment-1268502
    • Are you suggesting that the kit did a cheap and nasty job of just jamming the wheel in between other things and caused the misalignment? I mean, we normally do this with an integrated crank trigger wheel, not something bodged on. It's not 1995 any more.
    • I mean, given the number of BMWs you own their tolerance for improper torque is rather low. The number of torque + angle spec bolts and non-reusable bolts in one is nuts.
    • Atmospheric vent requires something that doesn't use a MAF for load. You would need a standalone ECU for that.
    • Hey all,   I’ve got an RB25 with a trigger kit that includes a crank wheel, and I’ve hit a wall trying to sort a timing belt tracking issue. The belt either rides right on the edge of the cam/crank pulleys or walks slightly forward once the engine starts. It tracks okay-ish for a moment, then creeps right to the edge—and honestly, it’s stressing me out.   I’ve spent hours removing and reinstalling the belt, double-checking everything:   Tensioner setup is good, checked multiple times Idler pulley and washers are all in the correct places Followed the RB25 timing procedure step-by-step     The only thing I changed was the rear crank washer—I swapped the OEM one for a Neato version, and it made things worse. The belt now sits even more forward than before. I’m beginning to think the crank trigger wheel itself (from the trigger kit) is the issue—poor design or slightly off dimensions.   What’s strange is that with the previous belt setup, it actually ran fine for a couple of years—around 4,000 to 5,000 miles, even with hard driving and high RPMs. But even then, the belt was always riding right on the edge, and I know that’s not ideal or safe long term.   At this point, I’m debating whether to:   Machine a few mm off the crank trigger wheel to bring it back in line, or Replace it entirely with a better-designed unit     Only thing is, I already have the Cherry Hall sensors, bracket, etc.—I just want to replace the wheel only, not the entire kit. Anyone know a brand or supplier that sells just the crank trigger wheel on its own?   Would really appreciate any feedback—especially from anyone who’s run into this exact issue and found a reliable fix.   Thanks in advance.
    • Hi...a little refresh. Is Nistune gonna be enough to run BoV? Or do i need some proper ECU?
