RB25/VG30 hybrid highflow Turbo?
Hey all.
I have purchased a RB25 S2 turbo that I am going to have highflowed along with a 360 Deg Thrust bearing put in. This will be going onto my RB31DET.
My question is. I know that people put the VG30 exhaust housing on the RB25 turbo for a performance increase. Would it be worthwile/feesable for me to put a VG30 exhaust housing on the 25 turbo before it is highflowed?
In my head it seems like an easy way to get just a Little more power out of it. While possibly giving it a little more punch from the 3L bottom end.
I know that this type of set up may cause surging and be a little laggy on a 2.5L but I think it should be fine on a 3L.
Thanks guys
If anything fitting the VG30 exhaust housing to the stock RB25 CHRA will decerease the chances of surge as it will shift spool to a later rpm where the engine is able to consume more air.
Give it ago. Maybe do a before and after power run just to give us all an indication how the larger a/r reacts with the 3ltr. :rofl:
I sure would be interested.
In std form the VG 30 ceramic BB turbo or its exhaust housing on the std RB25 ceramic BB turbo could work ok up to the ceramic turbines speed limit . These were fitted to a 3L VG 30 after all .
Be wary of bush bearing hybrids using the VG/RB housings , the ceramic turbine is the only one that really suits them properly . Boring the exhaust housing out butchers the nossle section and it can't work properly . Unfortunately turbos of this size need to run at high shaft speeds to move enough air , and the bush bearing and thrust plate / collar affair won't stand this for too long . Apart from the above options there are no cheap answers .
Cheers A .
Why would u have an RB31DET and put that skanky turbo in it? Why would any1 go to all that trouble and waste it on such a turbo?
Put a big daddy 35/40 700hp roller on it!
Disco: - I am getting the Rb25 turbo highflowed - that means 360degree thrust bearing. new seals - steel wheels - bored out etc etc. I want to put the VG30 exhaust housing on the turbo to give it even more go again.
Abused: Most of the reasons as above. I want it to go straight onto the car with minimal fuss. I'm not interested in a stupidly big turbo that takes ages to spool. This is my daily driver. I drive it to work and back home. Some weekends me and my girlfriend go away in it. Every now and then it will be off to the drags/track. Thats about it. The fact that it looks 100% stock as well. The truth is a Std high flow puts out 450hp. Hopefully just putting this extra bit on gives 470-520 hp (hope/guess) that is more than enough with my other mods for the streets.
Thanks guys please keep the info coming
That skanky turbo could very well make 250rwkw. :rofl:
Whilst i think plan bearing turbos are fine, if you have a ball bearing turbo, i dont see the sense when getting it rebuilt going to a 360deg thrust bearing setup? Other then expense of course, but there are places aroudn that do BB as well and are only a $200 more:) (approx)
Cubes: That's the hope :) a skanky little 250rwkw :rofl: (or more if possible :P)
I was recommended the 360 deg thrust bearing setup as it should make more reliable power. That's really why I am/was going with it. The other option was a 270 deg thrust bearing that would be cutting down the life of the turbo and the power.
I will ask about getting it BB set up as well.
Thanks for the advice roy.
Depends how much you can get it all for.. If you are buying from a jap wrecker you are better off getting your current turbo highflowed.
A little while back when I had the RB20t jap wreckers were asking around $700 for an RB25 turbo & $500 for a VG30DET BB turbo.
hey mate
I picked up a blowen R33 S2 turbo for $100
Have seen a few places that sell the rear housing for about $100-150
The highflow job with the 360deg thrust bearing is costing aprox $1300
After all of this I will still have my current RB25 turbo to bolt onto my mates R32. So that will bring the cost down a little
  • 3 weeks later...
doesnt seem worth it, maybe pay a little extra and get a garret 450-500hp roller??
I understand now why u wouldnt want to thow a huge turbo on it. My mates got heaps of power with a big turbo and its not as driveable as u probably want it to be!
All the best anyways!!!
Who is doing this stuff for you? The whole 270 degree vs 360 degree thrust bearing durability argument is kinda pointless if the shop that's doing it for you doesn't low-speed and high-speed balance the rotating assemblies for you, and you're going to be spinning it past its efficiency range anyways. Especially with the ceramic wheels, overspinning will lead do very premature failure. I'd say, save your money and get a real ball bearing turbo (not a single ball bearing unit with a thrust bearing), that is properly matched to the engine. You know we DO make turbos smaller than a GT40R... And it seems that for the prices you are saying, you could be coming close to just buying a new gt28R or gt25R with the t25 flange that will bolt right up anyways.
I'd say unless the shop you're doing this at is VERY reputable with turbos, you're only buying a temporary solution.
Rb25 and vg30 turbo's are T3 flanged and we have pretty reputable shop's doing this sorta stuff out here eg. GCG..
  • 4 months later...
I've got both a vg30 and r34 gtt turbo that i'm measuring up.
It appears the elbow from the r34 turbo will indeed bolt up to the vg30 turbo. The RB20DET elbow definitely won't.
I am unsure of the R33 rb25det turbo's elbow.
I've also discovered as have some others, that the R34 GTT turbo has the exact same size turbine housing as the VG30DET turbo.
sThe only difference between the two is that the R34 turbo runs a slightly larger compressor BUT it does have a anti-surge ring or what ever its called located in the snout which reduces efficiency.
Stock vs stock I'm not really sure which is better.
Larger compressor with an anti-surge ring or slightly smaller compressor without the surge ring.
Could you please do me a favour and measure the r33 rb25det turbine housing as the following pic illustrates and post the results?
Even just by using a ruler with a sharp eye will be good enough. :P
For example the cross section width of the rb20det turbo is ~45mm.
 Share
    • Haha honestly the thought crossed my mind but skylines are so damn rare here someone would probably hang me 😂    I’ve had a few LS swapped cars (280zx and a foxbody mustang) so trying something a bit different this time
    • Not much info in that request..... If you have a VIN you could look up the factory part number here: https://www.amayama.com/en/genuine-catalogs/nissan
    • 2.5 torque? 3.0 torque? Pft. Dude the van is right there. Consolidate your projects, put the LS into the R32 and have either a R32 with grunt, or a firebird that handles, however you want to refer to it. Either way you won't want to drive the Firebird or a RB powered Skyline ever again so this is the proper solution, and you cut down on projects. It makes sense even if you hate it.
    • Never mind the ash - the massive witness mark on the leading edge of the rear arch make little baby jesus cry.
    • Some small fixes made over the weekend. I've been trying to get the car sitting right on the 275's as well as reducing the rubbing as much as possible. I bought a guard roller but the lip within the guard is obviously made of high tensile steel because it took so much work and heat to get the smallest of movements that I totally flared my rear arches. It looks kinda cool.   I also got inside the arches with a dremel to cut down the bumper and the bumper mounts. The first one (pictured) got a bit ugly but the next one was much nicer as I just cut slots and hammered them upwards. I gave it all a spray of primer too. I'm still scrubbing a little bit on passenger side but it has less camber than the drivers, so once that is sorted it *should* be ok. I drop a single corner down on the ramp to simulate that mismatch and see where it is scrubbing.         Here's my flares. The car is lower than this now. Excuse the bush fire ash on the car.    I also haven't had windscreen washer jets for weeks so thought I'd tackle that. It looks like a leak is coming from under the headlight. Just in there. See it?  This would have been clearer and easier if I'd taken the front bar off, but basically the plastic hose connector has broken off the headlight sprayer. And because I couldn't be arsed taking the bar off and fixing what is already a gimmick, I just disconnected the feed hose and with some aquarium hose, circlamps and a drive shaft bolt I fixed it good. The hex piece I tried first did not seal too well (2nd pic) - not sure why I thought it would! 🤦‍♂️.   Because I hate things being broken, I will fix this, but until I could be bothered to take my bar off, this will suffice. Note the BMW push-in hose connector. Because standardised fittings are too passé. I now have an issue with my adaptive headlights always pointing too low and sometimes shaking back and forth when I'm driving. I'm keen to have these working properly. On another note, I bought a set of EBC BlueStuff for the front. I looked at so many reviews; DBA Xtreme (not enough reviews), Ferodo DS2500 (Super expensive and hard to find), Hawk HP+ (hard to find, not many track/street combo reviews) and some others. Was able to get the Blues pretty cheap (~$250 delivered). Also there's a motorsport joint in Hornsby that will supply and install a RacingDiffs LSD conversion for $850 which is pretty good. I know its not a proper LSD but I'm just not keen right now to spend $3500+ on a proper one. I figure I'll give this a go and see what its like, if nothing breaks I can sell the diff with this in and upgrade later if I want. There are some streets near me I cannot get up in the wet at all and just spin a lot in the dry, it would be nice to have traction on these. (I live on a big hill). My first ever skid pan is coming up on the 8th of Nov. Can't believe I've never done one. Really looking forward to it.
