Yes we can tell Roy.
You do need to say this is what I have done (times and mods/cost). Drag racers are the worst for the comments like, "Yeah I got a 14.2 but my tyres are shit, my fuel was old, the track wasn't prepped properly, my mum was watching, etc and I would have got a flat 12"
I personally don't like those kind of, 'could have except for' comments, but hey, who am I to rain on your dreams :).
I think you hit the nail on the head with the cost issue though.
Fatz is building (really slowly) an aussie R31 with SR20, silvia suspension and welded diff which should surprise a few people for cheap speed. I considered buying it off him but decided I'd rather spend more money on the 34. I'm not going to be faster but I will have speed, handling and comfort all in one package.
Yeh, i agree about "...could have ... should have.:("
As it stands, my times are my times....and thats cool by me. As long as i go quicker then my last visit then i know im improving as a driver, and thats about all i can really control.
My point...using my car as an example of the sort of lap times a modded GTST can do isnt a real indication. Hence the shopping list of dramas/problems.
If you want to spend 30K on a car that you will get a kick out of (10k car + 20k mods) then id say look at an EVO IV if AWD, or RX7, perhaps GTST if RWD.
If you said (10k + 20k mods, + fear of costs blowing out and extra coin each year on maintenance) then id say sure go the GTR.
LOL...im just making an even bigger ass of myself, ppl start to think that i dislike GTRs or think that GTSTs are better...which just isnt the case:)
I'm not agreeing with the costs thing either Roy.
Other than my gearboxes and tyre issues my car hasnt missed a beat on the track. Sctosman has only had "tree" issues. Emre has only had "wall" issues. And the other regular track GTR's I know - Tim, Ben and Frank haven't had any problems at all.
The only people that have had real maitenence problems have been you RWD set your car on fire boys.
I've always tried to be gentle on my engine where possible and so far *touch wood* there's been no signs of problems on that front. But the car still is punching out times that are good enough for me thats for sure. I can't see that you need to spend a lot of $$$ to make a fast track GTR. If you want a silly fast track GTR thats a different story but a bacic low maintence R32 GTR shouldn't cost that much. Being able to be happy with keep that level is the hard part with the GTR's even though you will still be quicker than 95% of cars out there.
Fair point. What year models and how many track kms have they the GTRs done? They are just about perfect for a club car, but as a track car i think the costs can get up there.
If i was building a track car for a series like Improved Production i would build an RX7 or GTST. If i had my time again with a club car, i suppose thats what i call my, yours Scotsmans etc etc then i would say the R33 GTR is the go if you can afford one. With most R32s you will just run into little age related probs.
budget isnt desided yet it will be a on going project will start in about a years time and will just start off with the basics zorst pod cooler fuel pump and some boost but the first thing i really want to spend money on is getting it set up right to handle then ill get serious about power looking at getting a uncomplied r32 gtst or a earler model rx7 around the 5-7 g mark should get a good one then spend about 5gs straight off on mods and then go from there
OK a cheap track GTR.....
R32 GTR about $10k-$15k landed
Full adjustable bushes kit $1000
Good coilovers $1500
Brembos $1500
Big swaybars $200
Really tight rear diff $200
ECU + tuning $2000
Cat back Zorst and front pipes $1000
High flow or no cat $300
Good dump pipes $500
Race Seat $300
Harness $500
Cage $2000
Fluids $300 per change (engine, gearbox, diffs, xfer case, hicas, ps, atessa, brake, clutch)
Racey brake pads $500
R or slick tyres $1500
17" rims to fit over brembos $1000
Catch cans $200
New Coil Packs $600
Torque Split Controller $500
Oil Cooler $500
You'll have a good, quick reliable car now.
And if/when you blow the engine:
Prepare block, crank rods etc $800
Forgies and Rings $1200
Head Reco $500
Sump Kit and welding $600
N1 oil and Water Pump $500
VRS Kit $500
Remove and install $1500
Labour $1500
If you want more....
Big turbs N1/2530/GTSS
Bigger Intercooler
Big Injectors
Big Fuel Pump
Light Flywheel
2 or 3 plate Clutch
Hey the sky is the limit with these cars :D
Duncan: Yeah but everyone knows r32 GTR's arent very quick. :jester:
Though jokes aside, BRASCO has a total budget of about 12-13k which would probably more suit the s13 or gtst with mods theory, as opposed to a gtr that needs money spent on it..
Duncan, sounds good:)
gtr jason...im willing to bet when you bought your car it was a good well maintained example? Do Snowman the service and kick some of GTST boys off the GTST list ... http://www.skylinesaustralia.com/forums/sh...ead.php?t=46199
LOL...you GTR owners are so easy to rev up:)
was looking at about 10-12g's straight up on car and a few mods
then about another 10g's after about 6 months to a year like i said it will be a on going project so really just want a little bit more power from stock then set her up right to stick to the track then i will get serious about power like oil cooler,bigger rad,aftermarketr ecu,injectors and maybe even cams
    • Anyone want to make me an offer to take my v36/g37 3.7l manual coupe in full? Off memory it was low 100k km but the battery is flat so can't tell right now. What's wrong. I had engine problem's that led to a nice clunk. It made it home but it wasn't pretty for the last few kms. Happened under revs. Sounds like bottom end.. never got around to fully checking or fixing it so the car has sat still and unregistered for a few years. Minor bump in front end set the pedestrian protection under bonnet airbag off and that was meant to be repaired, but while waiting for the repair (parts to come) I got the engine problem. The rest of the car is in decent condition. All drive line is good. All interior is good. Leather interior. Wheels in good condition and decent tyres although the ps4s are likely a little too old now it's sat still. Colour of the car is pewter off memory, the dark grey colour. In Camden NSW. Would need a tray back pickup.
    • I started with the above in my head too, and I might be reading / thinking about what they want wrong, which is why I complicated it a bit further. Purpose I'm seeing is for the corner indicator to be on with headlights, and then if the indicator turns on it can still flash. The relay part above I can see working as required, except in the case of headlight is on, and indicator is on. The change over relay you've wired in would get signal from the indicator, and as it flashes would give power to the globe from the indicator, but as it flashes off, power comes from the headlight, which would cause the indicator to be constantly on when headlight is on, even while indicator change over is flashing. That is unless we don't care if it flashes or not if the headlight is on? I guess that's an OP clarification.
    • HI, Ive got an r34 gtt sedan A/T. The instrument cluster went out and I replaced it with another A/T everything visually looks the same and all the gauges work now with the exception of the speedometer and odometer. The speedo will stay pinned at zero until I'm going about 55kmh and then it'll say Im going about 5kmh. my odometer seems to be tracking at about a 1/10 of what it should. If I go 1km it'll say I've only gone 0.01. Appreciate any and all help. Ive tried searching through the forums reddit and a local fb group. The only info I think I've found is that some cars didnt come equipped with TCS (mind is) and the clusters may be different between those? I've also installed a brand new VSS and no joy obviously. TIA.
    • what speedo healer did you use?
