hey guys....
this is going to sound wierd from a newbie.....
do any of you have pictures of your display and your promo girls from Melbourne Autosalon 2004....... and photos of the dyno promo girls or anything....my girlfriend did promo for you all last year and doesnt remember the site the pics of her are on.....
thanks... if you have any links i would greatly appreciate it.....
Peace :cheers:
https://www.sau.com.au/forums/topic/68439-just-a-question/
im not a stalker..... she is my girlfriend... i didnt want to put her name on a public forum....
i will pm you her name if you want.... but she is embarassed about the pictures and doesnt want me to see them... but i amallowed to see them if i can find them...but i dont want her to know that i am looking for them.... cause she is embarrased about them......if that makes sense
i didnt want to give names... cause i dont want people talking.....
Rhys
https://www.sau.com.au/forums/topic/68439-just-a-question/#findComment-1271061
  • 3 weeks later...
  R31Nismoid said:
if she was modelling i think we'd all know here name anyhow.
And no, she was not with us... i should know... i organised it  :D
hahahahahahaha
she was with you.... and she is doing promo with you again this year....... she said she would ask you for the link to the pictures from last year... but i know she wouldnt have cause she is embarassed.... so i thought i would ask anyway....
doesnt matter.... all good......
Rhys
https://www.sau.com.au/forums/topic/68439-just-a-question/#findComment-1326649
  SKY031 said:
As far as we know, you could be a stalker.
i was thinking the same thing.......
either that, or the girl is having you on considering the organiser, one Mr Nismoid, says that he knows nothing of her doing any promo stuff for sau
https://www.sau.com.au/forums/topic/68439-just-a-question/#findComment-1328844
Rhys
hmmm....... makes a little sense
but sounds childish!!!!!
https://www.sau.com.au/forums/topic/68439-just-a-question/#findComment-1328999
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
    • Sorry, I wasn't very clear.....just that the standard injectors are apparently good over 600rwhp/450rwkw which you won't get to on standard turbos anyway.....they are much better sized from factory than we are used to in RBs.
    • I'm not sure where you are, but United Terrey Hills has E85.
