hey guys....
this is going to sound wierd from a newbie.....
do any of you have pictures of your display and your promo girls from Melbourne Autosalon 2004....... and photos of the dyno promo girls or anything....my girlfriend did promo for you all last year and doesnt remember the site the pics of her are on.....
thanks... if you have any links i would greatly appreciate it.....
Peace :cheers:
https://www.sau.com.au/forums/topic/68439-just-a-question/
im not a stalker..... she is my girlfriend... i didnt want to put her name on a public forum....
i will pm you her name if you want.... but she is embarassed about the pictures and doesnt want me to see them... but i amallowed to see them if i can find them...but i dont want her to know that i am looking for them.... cause she is embarrased about them......if that makes sense
i didnt want to give names... cause i dont want people talking.....
Rhys
https://www.sau.com.au/forums/topic/68439-just-a-question/#findComment-1271061
  • 3 weeks later...
if she was modelling i think we'd all know here name anyhow.
And no, she was not with us... i should know... i organised it  :D
hahahahahahaha
she was with you.... and she is doing promo with you again this year....... she said she would ask you for the link to the pictures from last year... but i know she wouldnt have cause she is embarassed.... so i thought i would ask anyway....
doesnt matter.... all good......
Rhys
https://www.sau.com.au/forums/topic/68439-just-a-question/#findComment-1326649
As far as we know, you could be a stalker.
i was thinking the same thing.......
either that, or the girl is having you on considering the organiser, one Mr Nismoid, says that he knows nothing of her doing any promo stuff for sau
https://www.sau.com.au/forums/topic/68439-just-a-question/#findComment-1328844
Rhys
hmmm....... makes a little sense
but sounds childish!!!!!
https://www.sau.com.au/forums/topic/68439-just-a-question/#findComment-1328999
    • Just a follow-up on this topic. From what I can tell so far the rusty residue on the engine block might be unrelated to a coolant leak or maybe just older than anticipated. After driving it from the winter garage to my friend's garage I could not see any new traces of coolant leaking there, but I will test this properly once I was able to fully warm up the car and drive it for a bit. I think I can agree that the whole porous engine block stuff is kind of nonsense, but there is just a silly amount of true, false and half-true information on anything Skyline-related on the internet.
    • hrmmm , not mine , easter plans to pull engine not happening
    • I removed the IACV, cleaned it and reinstalled.  I found a video on youtube that helped with the whole process, the guy then said the idle needed to be set, so the process was to get the vehicle up to operating temperature, unplug the TPS, set the idle screw in the IACV so the RPMs were around 600, then plug the TPS back in.  After I reinstalled the IACV, the car started (because, it was a cold start), once it warmed up, the car died, I adjusted the idle screw to see if that helped anything, it did not, I had to wait about 3-5 minutes, then the car would start back up. Only to shortly cut out, and only crank.  I loosened the TPS to see if adjusting that would do anything, and when I would rotate the sensor clockwise, there was a humming noise, but it would go away when I got the sensor in the horizontal position.  It only made the hum noise with the key on.  What do you guys think? 20250414_172604.mp4
    • Quick update.  The engine grounding strap was replaced, the engine is now happily running.  Tested the voltage drop before replacing the strap, was about 1.2ish volts down between engine to battery, chassis to battery. With the new grounding strap, pretty much no voltage drop at all.
