to put it on the network, plug in a network cable, get to a terminal session and use ifconfig to set the ip address like so
ifconfig 192.168.0.10 255.255.255.0
assuming 192.168.0.10 is what you want to set the IP address to.
and then add the gateway like this
route add default 192.168.0.1
and dns servers into /etc/resolv.conf
in the format of:
nameserver 123.123.123.123
if none of this makes anysense, install windows, guessing that will be the best bet :thumbsup:
https://www.sau.com.au/forums/topic/68447-fedora-core-help/#findComment-1269540
hi pva glue
you can overwrite the root password if you have local access to the box.
boot the box up and when it comes to the lilo prompt or it maybe grub boot loader
you should be able to enter
linux single
when it boots it go to start mutlimode daemons, and then kill them all
once that is done it will boot to a prompt and say linux# instead of your systems name and it wont ask for user/passs as you get granted local admin due to the boot mode. you can then run
passwd
and set your root password to whatever you like. then type
reboot
and youll be done
if that doesn't work, get a boot disk from debian or slackware boot up and mount the root disk also, make sure it has support for your hard disk and then mount the disk in /mnt/disk or something then run chroot /mnt/disk then run
passwd
and it will achieve the same thing
https://www.sau.com.au/forums/topic/68447-fedora-core-help/#findComment-1269771
    • yeah, there's a country that recently started importing Skylines, I blame them.
