I heard you (it was a bit hard not to eh) :jk:
Some comments were a little hard to take with a smile on your face.
But I am a little ashamed to say that I had a giggle with everyone else about the Ferrari kissing the wall. :Oops:
El Bee :)
  • Replies 85
Guest two.06l
A fun weekend.
Must admit to being a little surprised by the anti Skyline sentiment in the "off street drags".
More than half the spectators seemed happy to barrack for a non-descript bucket hot rod thing with huge this and that. Anything as long as it wasn't that *&@#^$% GTR thing.
Thankfully there were some exceptions (apart from us).
El Bee
Yeah well being the pilot of the *^$% GTR thing, i felt like Jim Richards and getting the mic. and giving them (including the blind judge at the finish line) the ar5ehole line. We have it on video its nearly a car length, they just couldnt have their methanol/nitrous guzzling big block sh1t bucket getting chopped by a japanese car that drove to the event and back home again. Wont see me compete their again. Also i was not the only Skyline driver to have this done to him, as i believe 2rismo was also outed with a dubious call from the same finish judge.Paul...DIRTgarage.
I reckon we should do what they expect us not to do - turn up again. If you don't attend again, then they would have succeeded. I think we should show up in force with plenty of Skylines (and other imports). I know that alot of the rotor guys got the shits with the organisers/judges/event staff due to the obvious bias shown.
I had a blast drifting my skyline out of every turn possible was not in the drift contest as i have never drifted properly before but it was a blast to be able to do it and not get busted by cops or anything will definitely be there for August to do it all again. even put it on the dyno(Hopefully with the new Turbo)
With grooved ET Drag Slicks btw... And yes, I too got ripped off in the racing by a Commonwhore of all things. The promoter came and asked me if I thought I got ripped off later that day with absolutely no coaxing so it must have been obvious.
Paul, you know you'll be back in August if I have to DRAG you there!
Adrian
What excuse did they give you? We heard that you'd apparently jumped the start (sure didn't look that way from the grand stand) and that was why it was being re-run.
If they were saying it was because of the finish was uncertain, they're bigger wankers than I thought - there was easily a car in it, everyone could see that.
2rismo was definitely in front as well (only just)..
It was always going to be a meat-head fest though.. when the commentators started calling my GSR a WRX (and my mate's sprinter a seca!), I kinda got the idea I might have been at the wrong event :D
Oh well, I'll be back in August, I had a heap of fun regardless of the one-eyed bogans around the place.. putting them in their place down the main straight was more than satisfying!
Thwe video says he didn't jump the start and that he won by a car length. He did jump the start in the re-run though. (However the re-run should never have taken place.
I only *just* got there but as the wise man once said, "It doesn't matter whether you win by an inch or a mile, winning's winning".
I was well impressed with the power in that white WRX too. Pulled really hard even with 3 mates on board. Anyone know him?
Adrian
Guest two.06l
Adrian
OK ive had my sook....I"LL BE BACK!!!!!
BWAAHAHAHA!!! The guy with his back to the camera is Steve from Steve's Speed Shop. He came to say hi and drop off the smurf's blood (redline gearbox oil) and ended up spending half the day under twoogle!
:D
Adrian
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
