I am sorry I just call friend of mine he sold today early morning dark green auto for 15ooo.
But he has 1998 NEO engine manual,turbo intercooler,lather interior fo 25ooo$ registered.
And 2000 model manual,turbo 32oooK.
I am sorry I tried to help him to sell and get somebody lucky to own bargain Stagea .sorry
is gone they should colected car tomorrow morning with money.
Thet is no catch.You can not compaied car with big kms or bad condition or accident.These was bought straight from japan so no many hands to make money on it .It s way is prices so goog .Below average dealers or privet sells.
You can come to inspect car without buying and You will see.It is not so expensive to fly over and I can pick You up from airport and You can have a look.
I've noticed a few more coming in to the country in the last few months. And the interest for them is also starting to head up. People are starting to realise how good these things are :)
What sort of km are on these cars ? When I was looking for mine it was pretty hard to find one with under 60,000km on the clock.
Bbenny - drop me a PM and we can chat about the figure you had in mind.
J
These prices mentioned above seem waaay too cheap hey..
Yeah, I was a bit shocked when I saw the prices.
Mines a Dec 96 car. RS4-V with the all leather and electric seats. Dual sunroof's. 67,000 on the clock. Got the factory TV and CD stacker. Titamium silver.
Interior is just about spotless and the outside is totally straight and paint is spot on.
R34 Gtt mags are the way to go with Stagea's cause I've got them too (with new tyres). :D Got the factory front and rear spoilers as well.
It pulled a tad under 170rwkw on a 2 wheel dyno with a trust side mount intercooler, turbo back custom 3 inch exhaust, upgraded fuel pump, trust adj exh cam gear, high flow panel filter, oil catch can and a Unichip computer with the electronic boost control module set at 11psi.
Got the usual full alarm/turbo timer/pager system that rings you when the alarm goes off etc..
Mind you, the car was 100% stock standard when I bought it.
Pics are here (good pics on page 2)
http://www.skylinesaustralia.com/photopost...t=all&ppuser=63
Looking at the prices around, I think $21,500 ono maybe.
J
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
