Hi guys,
Took delivery of my R34 on Thurs and boy was I excited! My excitement was shortlived because it started developing a few issues namely:
Traction control could not be switched ON
SLIP warning light was ON the whole time
Tiptronic wasn't working
Auto went into limp mode (only had 3rd gear) intermittently
The check engine light would come on intermittently
Got the car plugged into a consult machine and had quite a few errors which could not be cleared. The dealer has given me a loan car for now and will be looked at on Tuesday after the easter break :cheers:
In my spare time I've been doing a lot of research on this forum and have learnt about the shift solenoids breaking down which I do hope is not the case. I was told that these problems might have been triggered when the detailers pressure washed the engine bay causing sensors to malfunction. In the meantime all I have been doing is looking at pics of my R34 which I took on the first day. CAn't wait to get it back.
If anyone on here has had similar experiences, I wouldn't mind hearing from you. Will keep you all posted of the developments and hopefully get to meet up soon.
Cheers
Jon
P/S its a 99 model R34 GTT 4 door
https://www.sau.com.au/forums/topic/68534-new-r34-owner-with-problems-already/
  • Replies 91
You don't pressure wash skyline engine bays. (I don't mean you obviously) I wouldn't be surprised that it all starts working normally when the water has all evapourated from the nooks and crannys where they sprayed it. What a dickhead move.
Sounds like the solenoids to me, just need a few more details.
When in tiptronic mode does it display the gear still, but just doesn't change?
Also when the solenoids go, the check engine light doesn't come on, just the A/T light.
The check engine light is probably from the pressure cleaning, check the sensor attached to the traction control servo on the intake manifold, if the plug has moisture inside it will trigger the check engine light.
The very worst situation is you've got solenoids that have died in combination with the coil packs, which is very likely on the R34's
when in tiptronic mode, it just displays the gears like you're still in auto. Nothing happens. The check engine light comes on when I'm in neutral, reverse and also other gears apart from D. The car was still driving normally when the AT light was not on. I only had to turn the car off and on again and the AT light would disappear. Would it still run normal if my coilpacks were F^&*ed? I'm looking on the brightside, if the coilpacks and solenoid are faulty then they will definately have to replace them under warranty! On the other hand if that were the case then I Probably won't see my car for another couple of days.....its being trucked down to Gavin Woods down the coast so I guess I'm in good hands. The dealer has been good so far and wants to get this fixed asap. Shit happens :P
Yeah sounds like what happened to me, that only worked so many times, until the solenoids died 100%...then that little A/T light just wouldn't go!!!
Gavin sorted my one out so no doubt he's probably the best person to send it to, he was amazed that the solenoids actually tested OK out of the g'box...but turned out that was because the fault was heat related, at room temp they were OK.
My ones were replaced under warranty...happened within 5000kms of getting the car.
I think it was a good 6 week wait for parts, I know it was a pain driving in 3rd for what felt like forever! You'll find the parts probably have good availability from Nissan NZ.
Got the skyline back today. Alls good. nothing wrong with the coilpacks or shift solenoid. Apparently one fuse was in the incorrect place (stereo installers fault possibly) and there was a fault in the secondary throttle position switch circuit. I'm glad I got it back today and hopefully fingers crossed it'll be all good from here on!
Looks like you have the pearl white there. A 1999 R34 GTT Pearl White 4 door. Can't really go wrong there.
Good to hear it's back and working although "secondary throttle position switch circuit" sounds a bit weird. Ahh well, who cares. It works now. Enjoy.
    • The water pump is know to leak as well. So if the coolant is low checking that first as well as hoses.
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
