  • Replies 155
MickieB - grab the all engine one for the RB20DET.. doesn't have chassis details, but will help you with the engine..
Manuals are back up..
username: sau
password: august
Cheers,
Links
  • 3 months later...
  • 3 months later...
  • 5 years later...
  • 2 years later...
  • 5 years later...
On 4/3/2005 at 3:26 PM, David Kemps said:
Может кто-нибудь, пожалуйста, поставить S14 и S15 там. Спасибо, парни
On 4/3/2005 at 4:11 PM, David Kemps said:
хаха хули только что проверил, есть s13, s14 и s15
это то, что у меня есть, если кто-то захочет, скажите мне, и я загружу его.
Nissan Fast
Руководство по ремонту evo4
Руководство по ремонту evo6
Руководство по ремонту evo7
Руководство по ремонту evo8
Руководство по ремонту s13
Руководство по ремонту s14
Руководство по ремонту S15
программное обеспечение для даталогита
350z руководство по ремонту
power fc - программное обеспечение powerexcel
куча других вещей апекси
On 4/2/2005 at 1:05 AM, SkylineGTT25 said:
Thanks Buddy, all worked well.
Has anybody got the R34 Wiring Diagram Manual (Pub. No WD8E0R34J0) to add to the list of files ???
hello do you found  R34 Wiring Diagram Manual?
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
