I edit this to mean if someone gets a broken headlight contact me I want the back part.
Just got back from my Easter pilgrimage 1250kms and on the the way I hit a bird on the front grill which snapped the mount for the grill coming off the headlight.
I know how to plastic weld and was hoping that maybe someone had a headlight that was broken or something that I can cut the the mount off to weld to mine.
It just a piece of plastic about 5-6cm that cilips to the grill to hold in position if anyone can help it will be greatly appricated.
PS I posted here cause i live in brizzy
https://www.sau.com.au/forums/topic/68546-broken-headlight-mount/
I'd hate to be paying your fuel bill, hope you had some of those coles vouchers..
So now does the headlight just rattle around or something? I wonder if you can secure it with wire or something in the meantime if you can't find the part. I'm not near my car atm so not sure exactly what bit it is. I guess they'd be the same as an S1 so a wrecker should be able to help well enough, just don't act like you really NEED the part or they'll charge like a wounded bull...
Unrelated but I know of someone who recently picked up a pair of rear brembo calipers off an evo 6 for $50 from a wrecker!!!!! Then he looked around and found the front cut of the same car and got the front pair for $75!! These things are like a couple grand each from Mitsubishi!!
I think I'm gonna start cruising wreckers for bargains..
Oh yeah also do a search on these forums for any R33 front cuts that ppl might have taken engine etc out of?? If there's any around they might not need that bit.
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
