World Record....?
Guest DIRTgarage
In the Dyno shootout comp. yesterday, TWO.06L recorded a mind blowing 627bhp.
which is 467kw. Is this a new World Record for a GTR running 2530 turbos, or for that matter low-mount turbos alltogether. Jim from Croydons is sure it is but we would like to find out for sure. By the way nitrous-oxide running cars do not qualify and must be running on jap pump fuel or equavilent.(we ran VP 103)
https://www.sau.com.au/forums/topic/68548-world-record/
  • Replies 64
Chunky. Not bad for what I heard was a stock bottom end :P
Oh and I doubt that Jap bowser fuel is as oxygenated as the VP gear, how much timing did you end up winding into it?
Good results anyway, time to do some benchpress practice with gearboxes :)
https://www.sau.com.au/forums/topic/68548-world-record/#findComment-1270962
Guest two.06l
4% more than what we had?? I think?
don't think we have ever said it's a stock bottom end? We will have different box again for next event, should be better.
https://www.sau.com.au/forums/topic/68548-world-record/#findComment-1270985
ill try but im sure it was like 2 yrs ago since ive heard of it
could have been low mount 30's or 28's... cant remember off the top of my head. was almost unbelievable cos u wouldnt think u could low mount those bigger turbos.. but aparently was.
at this stage uve got the record n we will stick to that :P
https://www.sau.com.au/forums/topic/68548-world-record/#findComment-1271071
or as a quick reference:
Posted by: Guy R
Here are the results from the low-mount turbos, on mine and Henry's car that we both own!
My car (2.6litre, wild cams)
Max on 2530s - 560bhp
Max on T618Z - 672bhp
Henry's car (2.8litre, mild cams)
Max on 2510s - 554bhp
Max on T517Z - 635bhp (only 1.5bar)
Conclusion, from 2 cars on rollers:
The HKS GT2510/2530 will struggle to get 600bhp.
The Greddy T517Z and T618Z are noticeably bigger, still low-mount and easily capable of flowing 600+ to 700bhp.
The above are facts as tested on a MAHA dyno in England.
Guy
https://www.sau.com.au/forums/topic/68548-world-record/#findComment-1271075
Hey now that you mention it....
Phoenix's Power (http://www.phoenixs.co.jp/bigsite/home.html) have got a few near that power figure. From their power rankings:
1) BNR32 - R34 N1 turbos, PowerFC, cams etc : 645.5PS (636.6HP/474.7kw)
2) BNR34 - HKS GT-SS, PowerFC etc : 634.1PS (625.4HP/466.4kw)
Will check out some others.
https://www.sau.com.au/forums/topic/68548-world-record/#findComment-1271084
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
