World Record....?
  • Replies 64
Excellent work and congrats on the record runs. Highest I could find for 2530's on a GTR after a quick search is 501hp@wheels in an R33:
http://www.linney.org/pmj.htm
And this R33 GTR that has a claimed [email protected]:
http://skylineowners.com/forum/showthread....9616#post149616
One more R33 that has a claimed 641(hp)@wheels:
http://www.ridejudge.com/ridedetails.asp?RideID=8152
The Phoenix runs are on a 4WD chassis dyno.
But anyway, how can you possibly lay claim to the world champ 2530 title without a fight? However, you'll get your chance at WSID on April 9 when a special guest is flying in to defend his world title..... Ladies unt Gentlemen, I give you (drumroll)
Hulk "2530" Hogan, reigning world champion!
Guest two.06l
Would love to know if those Japanese/English/Australian power figures were on chassis dynamometer???
Timing was an extra 4 deg for that run.
Adrian
anyhow...how awesome was it 2rismo....your reaction on the video was priceless. Can you host it somewhere, maybe when you get back to work (dial-up boy).
In the Dyno shootout comp. yesterday, TWO.06L recorded a mind blowing 627bhp.
which is 467kw. Is this a new World Record for a GTR running 2530 turbos, or for that matter low-mount turbos alltogether. Jim from Croydons is sure it is but we would like to find out for sure. By the way nitrous-oxide running cars do not qualify and must be running on jap pump fuel or equavilent.(we ran VP 103)
That is absolutely mind blowing and congratulations.
Can I ask how you can get 600hp turbo's working well over their designed limit.
Don't get me wrong but my understanding is turbo's are rated for X amount of power and your combination exceeds the 2530's capability by miles.
Just wondering how it's possible. I understand if you don't won't to give away any secrets but could you provide a broad explanation on how you achieved it.
I don't wish to take anything away from this great achievement I am just really interested to know that it is possible.
Cheers
Guest two.06l
Great result!
If you have std diff ratios it looks like you're well over the 9 grand mark at the top of fourth? What rods and crank are you running?
Cheers
Gav
Don't you remember us Gav.....we are the ones who do cryogenic treatment. The run was to 8000...our redline is 9200. The rods and crank are stock and our diff ratios are too.
Guest two.06l
Cheers
Thanks for the congrats.....well it goes a little something like this.......HKS rate their turbo for the worst possible senario. eg on a stock engine using poorly designed manifolds and dump pipes (stock), standard head,cam timing,intercooling,piping etc.
The more efficient you make any of these pieces of the equation, the more efficient the turbos will become (minimise the losses in the system) Every part of our set-up has been thououghly examined to see if we could cut/minimise the loss and therefore increase the turbos efficiency. Correctly selected camshafts, portmatching of manifolds, and CORRECT porting of head play a crucial role in this.
The velocity of gas flow in the turbine side of the system has to be taken into account when porting a RB26 head, we believe we have got this part of the build spot-on. Too many times old school principles have been adapted to RB26 or for that matter any modern turbo engine build-up and the results have not been forthcoming.
HKS 2530 turbos are designed to be efficient at between 1.4-2.0 bar the results on the weekend were achieved using a lowly 27psi. I think in my own mind that their HP rating should only be used as a guide and not as a maximum figure. As a rule of thumb calculate at least 10-20% higher if you do the build correctly. Paul.....DIRT garage
    • I like it when the counter chick leads you out the back into the racks and says "have a grub around in here and see if you can find what you need. I'll be back in a few minutes. Just left me in front of a massive motorised shelving system and 2-3 million fasteners, so I could find a peculiar SS shoulder bolt with cap head. Gotta love country towns.
    • I used this https://osgiken.com.au/product/os-giken-os-250r-lsd-gear-oil-80w250-1-litre/   shut my nismo 1.5 pro up by heaps…. Not silent though. Gives the car character and personality. It ain’t a carolla. If you want silent, put a quaife in it.
    • It's about the same time for me from Bunnings, or the Fasteners. My big push away from takeaway food, and gluten in general keeps me away from the Bunnings Snags too! Weather up here, I've been out for two walks today in the beautiful sunshine. Had a few little drizzles, and some wind, that honestly, a tin of beans and I could compete on how harsh she blows Thankfully, being this bit inland, we're not getting anything much really. Will probably pick up a bit more when/if Cyclone Alfie decides to come ashore. A few areas in the GC though, and south into NSW are really getting smashed though! Right now, I'm just annoyed Alfie hasn't hit, as I'm not allowed to crack into the BBQ foods like the bacon and eggs until the Cyclone hits "In case we lose power"...
    • I love fastener joints, the price difference between them and joints like Bunnings or Super Cheap is amazing, and they either have exactly what you want, or they can get it to quick They have even given me some for free when I only needed a couple of specific size In saying this, I have paid premium for fasteners from Bunnings if they have the sizes I need, but only for convenience really, as my local is only 10 minutes away, the Sushi joint near them is also a consideration  How's the weather Matt? Stay safe mate
    • Wideband is worth setting up if only for tuning purposes. I would not mess with the ignition system unless there's a misfire. HKS crank trigger is popular out here for the relatively easily sourced Denso crank sensor, not a bad idea to install as well regardless of power level on a standalone. Boost leak test is worth thinking about. Oil pressure sensor tied to a fuel cut isn't a bad idea either. Getting the tune figured out is a good idea. Without putting eyes on it and getting under it there's no way for us to tell you exactly what it needs but most likely you're down to the last 10% that will make a big, big difference in how happy you are with the car.
