World Record....?
Apparently the ultimate warrior is gay...that explans why you like him :D
Though, he never returned my fan mail as a kid so he musnt have been a patter ass:)
That is a brilliant result with the 2530s, congrats. Not knowing your tyre size it looks like the dyno run was stopped at about 7,800 - 8,000rpm. The setup seems to pull hard all the way to over 8,000rpm with the power figure not falling over.:)
Are you running a PFc? Are you able to give us an approximation of the difference in inlet temps between say 1bar and 1.7bar?
Congrats again, the car looks trick and has plenty of mumbo, shame its a drag car not a circuit car:)..................................................j/k
  • Replies 64
Don't you remember us Gav.....we are the ones who do cryogenic treatment. The run was to 8000...our redline is 9200. The rods and crank are stock and our diff ratios are too.
Yer - course I remember the "discussion" :D
The reson that I'm asking is that before I destroyed my recently rebuilt engine, I passed the traps on the quarter spot on 200km/h and the tacho was around 8500. Unfortunately I never got a chance to see what the GT-RS terbs could really do in anger, but I reckon I've got the right "ingredients" to chase your outstanding result.
BTW - looks like I'm gunna have another chance for that cryotreatment!
Guest two.06l
That is a brilliant result with the 2530s, congrats.  Not knowing your tyre size it looks like the dyno run was stopped at about 7,800 - 8,000rpm.  The setup seems to pull hard all the way to over 8,000rpm with the power figure not falling over.:D
Thanks Roy
you are right on the money with the 7800-8000 estimate
we are running power fc . An inlet temp comparison can't be given....but we used to run a thermocouple in the plenum, with only ever 4-6 degrees above ambient recorded.
Hey Roy, its a street car...................lol
Guest two.06l
What happened to the engine?
What was your MPH/ET?
Go the cyro buddy, for the price you'd be mad not to.
Just because you have the ingredients does not mean you can bake the cake.
Good luck with your build, and see you on the strip.
True that on the "ingredients". Will get there 'tho!
11.68 @ 124 mph, with what was a "conservative" tune on 17 psi boost and supposedly conservative timing. Just worked out why the tacho was out - was running MT slicks on the back!
Don't really want to go into what happened to the motor on public forum, water under the bridge with a Perth tuner
Guest two.06l
Yeah the reason why we built a new engine was due to a (and i use this term very loosely) tuner. We only use the best now, he might be expensive but its a hell of a lot cheaper than a rebuild.
Getting a cro-moly cage fitted tomorrow, as 10s are on the cards.
Paul, who is doing the cage for you? Care to pass on some details as I might know someone who might be needing one in the not to distant future.
One thing that really impresses me is the fat power band. Plenty of power and average HP is very high, not peaky like some dyno queens. Well done again.
Guest two.06l
A fellow by the name of Adam, Croydons put me on to him as he does all their work. when you need him let me know and ill pass your details onto him. Seen some of his work on the weekend and it is indeed "the sh1t".
Guest two.06l
Saw it out there on Friday and it looked fantastic! :D
What sort of fuel system do you run?
should have came and said hi, we run intank Bosch (swimmer pump 500hp) which feeds a 2 litre surge tank feeding two Bosch motorsport pumps (044). dual fuel lines connect to a TRUST twin entry fuel rail with SARD 720cc injectors. Then it is centre tapped to a SARD regulator feeding back to the surge tank. The whole system uses 3/8 braided lines with Earls connectors.
Guest two.06l
In this months hpi M-speed japan have a race car GTR runing 2.8lt with 2530s making 630ps or 636hp dosent say what fuel they are runing.
If its a race car id say its using race fuel not pump, spoke to Jim at Croydon's today and he's getting very excited about the cars potential for more! Like running 32psi instead of 27psi and better boost control and more fine tuning.
Guest two.06l
Mate whats Jims thoughts on pushing standard rods to this limit or past it?
Jims view is the rods are ok its the bolts and bearings as well as the clearances used. He has another car in the shop making over 500kw with stock rods. We break one it will be back to the ol' drawing board! Hope you haven't put the omen on us.
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
