ive seen a back lexus in aus with a massive wide body kit, proba an extra 5-6" wider on each side. this is tame compared to that one. whether they will let it pass i dunno but it looks factory enough to talk your way thru. if this lexus and those kakimoto wide body liners are allowed on road i dont why this kit cant. im no expert...lol
ps is that a 32??
yeah, its nice... but the only reason you'd get it is if you were overly concious about weight differences betweent he R32 and the R34, wanted a RWD with GTR looks, or couldn't afford a real R34.
The guys in Canada will be all over this kit as they can't own anything other than 15 eyar old R32's. Over here its a slightly different story. That said, a guy in SA has made his own R32 -> R34 conversion, not as phat as the Bee-R R324 but still pretty clever.
I've seen that car in the metal and to be honest only hardcore Skyline enthusiasts can spot that it's really an R32... but when ordinary people figure it out they do it's like "oh..." you know? Like they got excited that it was a legit R34 then realized it's just a poor old R32 :) thats what happened while I was at Osaka Auto Messe...
i think its awesome, the japs are getting crazy with front end conversions, just recently saw an R32/180 conversion.
something different, yet tasteful. i dont think its got anything to do with making your r32 into a 34 because you cant afford it, the conversion costs around $10000, if youve got $10000 to spend on a front end, you can afford a 34.
cheers
Linton
I saw the Bee-R 324s at Tokyo Autosalon and I have to admit they did look pretty good in the flesh. I think the photos don't do it justice. Personally I think that an R32GTR looks better with an R32GTR front end. It's a beatiful, purposeful shape and should be left as is imo. 34GTRs are nice too in a different way.
Personally my GTR will stay as is body wise, expect for re-spray in the stock Gun Metal Grey :D
Why bother doing this to your 32?? I've seen the Bee-R cars at TAS and also at Tsukuba testing at a Battle Mag event and I wasn't particularly impressed. FRP kitted cars might look impressive at shows but when I saw the car out in the open I thought it was pretty badly finished (not to mention it had a broken bumper!). Orange peel due to poor FRP, questionable panel fitting....nah...keep 32s as they are! There is nothing wrong with them!
  • 13 years later...
    • How's everyone going? Just a shout-out introducing myself. I'm James, I live on the north side of Brisbane. I bought an R33 that had been left to rot in someone's front yard for 14 years. Apparently, it has immobiliser/fuel issues. Long story short, it's suffering from a seized engine, plus whatever else turns up once it runs. The car is pretty good considering it sat for so long. It pretty much died after being imported. It has a bunch of Jap parts and a full Top Secret body kit. It's painted Fiat Turchese Festival, or aqua blue if you're not French. Another project to throw money at!
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
