Hey ppl wats up! Im new 2 this and jus bought a 1996 R33 GTS SpecII and any suggestions of wat i can do 2 make it look and drive beta (without voiding my insurance) would be much appreciated!:)
Also does anyone know of any bodykits? do specI bodykits fit a specII?
And finally wat mags? wat colour? (chrome, gold, silver, white?) by the way its gunmetal grey
THANX HEAPS ANY COMMENTS WILL B MUCH APPRECIATED! ;):):mad:
https://www.sau.com.au/forums/topic/6856-jus-bought-a-skyline-what-can-i-do2it/
1st thing is to ask your insurance company what they will allow you to do.
The start with an exhaust, air filter and a front mount. then BOV I would say ;)
good starting point then the possibilities are endless :) hehehe
Hey Tony - yeah he said it was a GTS.
33Spec: congratulations on the car, looks very nice (just like mine! :)). In regards to body mods, I think the side skirts and rear skirts make the car look good. The car looks a bit round under the door without them.
Also, the Nismo chin spoiler is cool, but some people like the S2 stock, your call.
Side skirts: http://202.139.242.57/images/gtrForSale/si...ideskirtblk.jpg
Chin spoiler: http://202.139.242.57/Images%202/Skyline%2...n%20spoiler.jpg
Cheers,
Tim
Pretty much anything will void the insurane if its not "standard". Even if its like racing pedals, which to me would have no discernable difference to the way the car drives, they will want to know about it and it might effect the amount you pay. Some of it makes sense, but in general its all a scam to get you for more money.
Best thing is just to ring them "I am thinking of fitting a xxx to my car, how will that effect my insurance?" and they will give you the answer. Depending on how much you want to take the risk, you then do it anyway, or just go without.
Remember if you are involved in a major accident, and you have fitted something you haven't told them about, and they happen to go through you car with a fine toothed comb (which has been known to happen, but not many times) - they are on the right side of the law to not cover you at all for the claim. If you hit a porche then...
Dont forget that some specialist insurers like Just Car and Famous allow unlimited modifications.
If however, you are talking about a standard insurer like Nrma etc then mods will more than likely void your insurance.
It pays to double check before you do the mods in any case
tlai909: you beat me to the N/A comment, first thing i saw was the 4 stud wheels :)
Thanx 4 all the comments!
Yeah i thought about buying a turbo but insurance is a bitch!
so i think ill wait a couple of years when im over 21 then fit a bigger turbo unless you know anyone that will insure me for an imported turbo its a no go DAMn insurance companys!;):D
Also thanx 4 the bodykit ideas Timmy G i might hav 2 get me sum of them! 5 stud conversion 4 the wheels interesting! does anyone know how much this would cost another thing is my car is being complianced as it just came from japan so i dont get the wheels you see so does this mean i can get 5 stud ones?
:D
why dont you get the wheels?
you probably misunderstood them when they said you need new "tyres".
there's no point in changing to 5 stud by the way.
there are plenty of 4 stud wheels that will look good on the car.
wanting to change from a 4 stud to a 5 stud...sorry about this...that is the dumbest thing I have ever heard.???? why would you want to do this? to give people a false sense your driving something ur not??
5 studs wont fit on a 4 studded axel anyhow? and I imagine it would be costly and a waste of time to do so!.
dont be so harsh on the fella akeenan
anyways it can be dont but it is time consuming and costly.. i wanted to do that also, change from 4 stud to 5.... mainly coz the turbo parts are so much easlier to come by and swap around rather than the 4 stud kind, and i had my eye one these mags that only had a 5 stud pattern......
bottom line if u got the time and $$$ and there is a point to the plan then do it, but if its just to have the fakeness as akeenan so nicly put it, go break yo self!?!? :lol:
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
