Hey,
I have done a search of the forum but nothing has come up on these issues.
(p.s correct me if i am wrong - i think it is a C210 :Oops: )
Over heating
For as long as i can remember my car over heats in summer. Like i cant take it threw drive thru or anything and i avoid traffic lights as at the stand still the temp just starts to creep up. I have had the radiatior checked about 10 times now and they cant find what is making it do it. But its encredably frustrating, so much i try not to drive it during the day in summer.
Fuel Problems
Well i think its fuel problems....As of late every now and then when i go to take off it seems as though i have left it in like 3rd or 5th - when its in 1st. It will chug and go to stall and sometimes not doing anything at all. I give her alittle bit more gas, but always my luck she takes off spinning wheels - just waiting to get pulled over by the cops... But i have a full tank of fuel, been running unleaded in her cause they arent selling leaded many places around here anymore. Using that Valve master stuff though.
Any advice on either would be great... I have a few other problems that would be great if i could get some help with as well too - but ill wait and see if anyone can help me with these first... :P
Thanks in advance for the help
Bek
https://www.sau.com.au/forums/topic/68577-c210-over-heating-and-fuel-problems/
Have a look to see if it has a thermostat....also is the fan on the engine a clutch type or the fixed type...i dont remember what mine was, its got twin thermos now...if its a clutch type fan it could be stuffed. You could try running a little less timing...like 1 or two degs no more....
the fuel thing...
could be a blocked fuel filter or possibly just some dirt in the carby.. id try the filter first.
also could be a dodgy accelerator pump in the carb.....i could probably fix it in 1/2 hour, if i had it in front of me, but i dont, and its abit difficult to diagnose on the net...but i hope this helps.
Good to see another C210 coupe ;o)
:P :burnout:
Car just came back from the service. The mechanic said that the 'fuel problem' was actually a kinked coil lead. But didnt fix it, waiting for approval from the paying party... (i dont pay for the car - or its services) :D
Is this bad... ? And why did it happen.
obvious question but did they do a radiator flush?there might be rust/crud in it and is the original fan shroud still there (the big black bit of plastic that attaches to the radiator, with the hole in it for the fan)
Yeah they have done that a few times now... It even started to get hot today and it isnt even cold... :) Silly thing. Oh well ill just get a new engine and new radiator to match - all problems sloved :)
Car just came back from the service. The mechanic said that the 'fuel problem' was actually a kinked coil lead. But didnt fix it, waiting for approval from the paying party... (i dont pay for the car - or its services) :(
Not really sure why your mechanic said that! Sounds like he is suggesting that you can shut off the spark by crimping the coil lead (just like shutting off water by crimping a hose). HUH??
Some things to try:
Check cam timing (engines tend to run hotter if cam retarded).
Check ignition timing - although mechanic should have done that.
Check vac advance mechanism in dizzy - although mechanic should have done that.
Overhaul the dizzy.
Overhaul the carby.
None of the water hoses have been bypassed or blocked off?
Try some Nulon "Total Fuel System Cleaner" in the fuel tank.
No the over heating is unrelated
Yeah i have a feeling that he was just making crap up to push me off - cause he wouldnt explain it when i asked (see the draw backs of being a girl - he said i wouldnt understand).
there is talks of me getting a 88 prelude for my 21st in 2 weeks, so the skyline might go back to dad and these problems can be his again...
nooooooooooo...the prelude is an old peoples car, give it to ur dad....keep the skyline...the skyline......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......the skyline.......
That is all.
    • Is there a way to adjust all of the pedals in an R32 GTS-T? they all sit even, but seem to be a little high for my liking.
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
