Automatics
Gary2
 Share
Craige that is an A box and I have just got the trannie upgrade (valvebody) and it has made a big difference in my book as the shifts are alot tighter and don't hang (lag) when changing.  Feels like a different car.  Well worth it.
Cheers ICE
Thanks for that info Shane. Where did you get it done here and what did it cost?
Cheers ..... Craig
  • Replies 40
Thanks how about an rb25det neo?
No problems, stay under 300 rwkw, big transmission cooler, use good oil and a valve body upgrade. If there is still a bit too much slip first to second, you can upgrade the drive belt to a kevlar one. Usually the 3rd gear clutch pack is OK at that power level, but it can be upgraded as well with 2 extra plates.
For about the price of a good multiplate clutch (in a manual) you can make a very strong auto.
:D
:rofl:
Thanks heaps for the info
Cheers ..... Craig
I got the upgrade valve body from MV automatics in SA via SAU Groupbuy. I still cost me around $420 including valvebody, service kit, frieght and deposit. I got Palmerston powersteering and automatics to install it as I know him well and he charged me $333.00 to install the valve body and service kit and fluids. Very happy.
:rofl: ICE
  • 3 years later...
bringin up a very old thread . . . . .
i got a trans fluid leak, when cold says on the dipstick its full ... when hot it says in 1/4 full . . . ( but only just got it filled the other day)
sill question, would the leak reduce cooling temps to the auto box, hence why i get stuck in 3rd, (but turn car off and start again all smooth just taking off in 2nd i think)
my gasket is leaking, bloke thought it might be the solenoids making it stay in 3rd, reading this i tihnk he's right, but if i just replace the gasket should it fix that problem ?
the auto trans guy didnt wanna just replace the gasket, incase it didnt solve the problem then have to take it off again and change the solenoids and a new gasket.
starts to play up with in 400meters of driving
Well, those were exactly my symptoms, and pretty close to the same symptoms as a heap of R34 boxes once they pass about 100-120,000K's... mine was shift solenoids; the new rack costs just under $500 plus fitting of course, and replaces all solenoids I think (at least A and B, pretty sure that's all forward gears) and some pressure regulator, which was playing up on mine.
The symptoms with these solenoids are that when they heat up they start to fail (and as soon as they do, they trip a fault code, and auto goes into limp-mode and you're stuck in 3rd... ALL THE TIME... it sucks :)).
Best of luck... but I'm not thinking that replacing a gasket will fix your issues (unless you can't keep enough trans fluid for 400 metres). If it does fix it, I wish I had your luck!!
Edited by DaveB
its parked up now, has been for the last 4days, staying that way until.
well i think i better flat bed it then, 170 to flat bed it there, crack open the box, tell me the good new, drive home, under 400bucks and a smile,
worst case, 170,plus new solenoids, plus service kit, plus gasket, plus labour. no smile !
170 is racv total care for a year, that is unlimited free tows :)
170 is racv total care for a year, that is unlimited free tows :P
yeah im on RACV total care. but i think they only deal with you if your broken down.
i could drive half way there and then call :/
Dude, get a massive transcooler.. you would be suprised the difference a good transcooler can make..
yeah im looking at those now :D . when i get the tranny fixed get them to tap it into the oil lines.
i want it on the front right vent in a V-shape so i can have the oil cooler there also :)
i could drive half way there and then call :P
yeah im looking at those now :/ . when i get the tranny fixed get them to tap it into the oil lines.
i want it on the front right vent in a V-shape so i can have the oil cooler there also :D
the amount of times i went home to a shop in the datto...
Trans fluid should be checked when hot (i.e. when the fluid isn't sitting in the sump). A fluid leak and resulting low fluid level can cause all sorts of erratic behaviour, the pump (driven by the converter) can have a hard time maintaining flow. Then the converter itself might be low empty, which will cause intermittent drive. It all goes pear-shaped when there's not enough 'hydraulics' to actually make a hydraulic drive...
Getting the box inspected would certainly be a good idea if you think that there's more too is than a small leak. Good luck
  • 2 months later...
Hi boys and girls i have had a series of let downs . As my s2 has been locked in 3rd or some peeps may say limp home mode . But oh no that is not the prob . I visited a good auto trans guy and pointed me in the right direction . I was told it was the shift valve solenoid . Sweet i thought go and order this part and fit it myself . 3 weeks later with filter , gaskets and solenoid . Its just the same $500 don the drain . Then found gbox trouble shooting on this forum . Nissan supplied me the wrong part ! The part they told they were going to supply was not the part that i was supplied . Now ordered the other solenoid . Another $415 i hope this works will be fitted tomorrow . fingers crossed . Here are the part numbers for solenoid a & b . solenoid A - 31940-4ax02 solenoid B - 31940-4ax05 . PLEASE DONT LET YOUR PARTS INTERPERETUR SUPPLY YOU THJE WRONG PART !!!!!
where you from Cory?
wish people would state where they are from in there little profile, makes help alot easier
Hi TJ ,Cory`s in SUNNY :D:blush: PERTH DUDE ,
ahh thanks chuckie.
well got no help from him out there lol :D
but mine was doing the same thing, wasnt the solenoids though, they thought it was but not to sure but wanted me to buy new ones anyway $500 just incase.
So i took it to another place they weren't confident it was the solenoids, so they opened it up, seem like the bands and clutch packs were worn, got a whole new rebuild (cheap) and still got the factory solenoids running fine :blush:.
HEAT is a factor for the solenoids also to go into limp mode, check temp's and leaks, have your got a Shift Kit installed ? they cause alot of heat inside the stock box because alot more stress and pressure being put through the standard items ....
Good luck any way Cory
ahh thanks chuckie.
well got no help from him out there lol :)
So i took it to another place they weren't confident it was the solenoids, so they opened it up, seem like the bands and clutch packs were worn, got a whole new rebuild (cheap) and still got the factory solenoids running fine :D .
Yeah chuckie is right perth is correct . It was the solenoids have replaced both all is sweet now bar the fluid leak i have which will be sorted tomorrow . I dont wish this prob on anyone especially if you are doing it yourself . Just be carefull you dont drop anything when you pull it apart such as springs and washers . But if you do good luck .
 Share
