I have a 1995 R33 GTS-t For Sale.
$19,000!!!!!!
White, 2 door, 5 speed manual, Drivers airbag, Electric sunroof (factory fitted).
It has an APexi Power FC with hand controller and Apexi Boost kit. Apexi 90mm exhaust from front to rear ( Front pipe, CAT, and CAT back is all Apexi). Lowered Apexi springs, 18 inch ANZ wheels. Factory side skirts, front bar and rear spoiler.
Trust Front mount Intercooler with custom Stainless steel Intercooler piping (which is all Tig Welded) Heavy duty truck hose clamps all round. Apexi Super power Pod filter, Strut brace, Turbo timer, Apexi Boost gauge.
Clutch was replaced less than 500km ago with a heavy duty item (standard pedal feel). Brant alarm system.
Currently it has 93,000km on the odometer which is genuine. All paper work has been held including compliance papers.
I bought the car in July last year and have done 3500km in it. I only drove it on weekends and was not a daily driver.
I have since been relocated to Western Australia for work. I have no use for a Skyline on a Minesite in Outback W.A. so I have decided to part with it regretfullly. My dad is selling it for me.
The Car is located in Melbourne.
$19,000.
0411-859-772
I have no way of posting pics of this car up becuase I am using the internet at the mine which you cant download or upload, sorry. This is a geniune sale and not some scam. Please call the mobile number above to arrange an Inspection. This car is in Faultless condition, which is why I bought it and will not dissapoint.
Cheers.
https://www.sau.com.au/forums/topic/68594-1995-r33-gts-t-for-sale/
  • 1 month later...
    • Is rebuilding it even a thing? Where would the shop find parts for it? I looked at some off these local online stores for my r34 and suprisingly they had brand new aftetmarket ones for $600-800 I think. I guess r32 might be a bit tougher.
    • I remember the days when E85 was priced in according to the $ per km outcome. Sure E85 was about 35% cheaper, but you also lost about 35% range... now it's fked..
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to move wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
