a long shot - but dont suppose you have the actual a spare actual little hook on the right hand side rear pillar that the horizontal cargo cover hooks onto?? Mine is snapped so can only attach one side :rofl:
Anyone?
Also a front cup holder tray?? Bloody stereo install guys snapped it when fitting audio gear :rofl:
https://www.sau.com.au/forums/topic/68604-delete-please/#findComment-1273482
I have few cargo bariers for sale .Two pieces one net going behind the rear seats verticaly and second part horizontaly is a roll cover with small hooks.
Net is a dark ,grey /black?/and roll cover is a light gray colours.
120$ plus P&H.
PM sent on Tuesday, no response yet, did you get it?
:cheers:
https://www.sau.com.au/forums/topic/68604-delete-please/#findComment-1276044
Sidney kid You sounds very happy to me today  ,after You instal cargo barier.
Thanks for the great service, as you can see the cargo cover and barrier are installed.
The cover is actually quite clever, much better than others I have used. It is far enough back in the load area so you can still recline the rear seats. And now I know what those hooks are for on the handles above the rear side windows. The cover hides my bits and pieces carrying box and the occy straps that hold it in place. At the moment it has several hundred dollars worth of brake rotors in it on their way to Eastern Creek, so it is good that it is covered.
:P
https://www.sau.com.au/forums/topic/68604-delete-please/#findComment-1290166
SK could you take a photo of the blind part not in the car? I'm interested how the mounting goes. It's going to cost quite a bit to get one of these here to NZ as the guy selling them can only get it shipped at $220 Aussi to me. making the cost phenominal to me to get it here in NZ dollars.
Anyne travelling to NZ and feel like bringing a cargo blind with them? I'll be your bestest mate :D
https://www.sau.com.au/forums/topic/68604-delete-please/#findComment-1294682
The blind simply "plugs" into those big square holes in the top of the plastic mounts on the wheel arches. If you look inside the holes you can see the steel clips that hold the roller case and stop it from rattling.
When the Stagea gets back from its trip to Canbra I will take a photo for you. It's back for 2 days, then I am off to Sandown for next weeks race meeting and to deliver an RB31 and pick up an RB25. Love that cargo space:cheers:
https://www.sau.com.au/forums/topic/68604-delete-please/#findComment-1294746
  • 1 month later...
More photo's?
https://www.sau.com.au/forums/topic/68604-delete-please/#findComment-1403576
Cargo bariers for stageas is a optional .They not coming as a standard acssesories is way cars coming from Japan without bariers.Because is optional You can not ordered from Nissan dealer.You can get only from Japan new or second hand.
Edited by familka gtr
https://www.sau.com.au/forums/topic/68604-delete-please/#findComment-1417042
When the Stagea gets back from its trip to Canbra I will take a photo for you...
Could you (or someone!) take some photo's of where the vertical net connects on each corner? I'm still hunting around just for the vertical net (as the stagea I've bought - that hasn't arrived yet - has already got the pull back cover..).
And are they the same on a series 2?
Depending on the conection, I might end up making my own...:-)
Ian
https://www.sau.com.au/forums/topic/68604-delete-please/#findComment-1417127
  • 2 months later...
Hi familka gtr, you don't happen to have or know where to get a driver's (RHS) wind deflector? I lost mine going down the freeway a few weeks ago, frightened the beegeesus out of me.
:( cheers :)
PS; the cargo cover and net are going fine, best value thing I bought for the Stagea.
https://www.sau.com.au/forums/topic/68604-delete-please/#findComment-1564420
:( cheers :)
On the subject of wind deflectors how do I go about getting a full set for my S1, this should stop the wind noise when travelling a high speed other wise may have to get new seals.
Cheers ICE
https://www.sau.com.au/forums/topic/68604-delete-please/#findComment-1564637
    • A few things that seem a bit off here. - why is there 2 BOV’s?  - the turbo smart BOV on the compressor housing, is it turned up ALL the way? I have seen this become an issue on old man Pete’s car. It would push open and recirc, turbo speed would rise and the boost pressure would do weird things. - stock head? Does that include springs? - tried a different MAC valve? Is it plumbed correctly?
    • Photo of manifold showing gate location? I mean, it's 6Boost, so we probably shouldn't be worrying, but always wroth knowing what the layout is. Plumbed back to atmosphere? Or into the dump?
    • Yes correct. Also, I'd avoid applying it to soft paint (however I doubt you'll ever have to deal with it in practice). So any paint that hasn't fully hardened, could be a 1k paint that never fully hardened or it could be a 2k paint that was laid down thick and hasn't yet fully hardened.
    • Bit of an update to this one. Having some issues on the dyno that held us back (boost spiking) and I want to pass some info over you guys and see what you think is wrong with my setup. The current readout on this dyno is 462rwkw on a low reading dyno so keep in mind it is a real world 500rwkw setup on a hub dyno. Don't read into the power figure too much as a sign of the issue. The short and curly of it is: 2.8 Litre Racepace build RB25 NEO N/A Head with VCT (internally standard however ) Borgwarner EFR 8474  Turbosmart 50mm Straight Gate + Mac valve 6Boost Manifold 4" dump to full 4" exhaust (nil restrictions) Wastegate plumbed back in and all angles in the exhaust system are acceptable and not too sharp. GFB SV52 BOV in cooler piping  Turbosmart BOV in EFR Housing   The issue we are having is it comes onto full boost for example at 4000rpm and spikes to 24/25psi, before dropping down to 17psi before slowly rising back up to the target boost of 23psi. It was extremely uncontrollable and the tuner actually had to ramp in boost progrssively with each 1000rpm on each boost setting we selected to try and reduce the amount of spiking. Sometimes we would see a drop of 10psi from the peak at the beginning of the run, to the low, until it took the next 500-1000rpm to stabilise back up to the target boost. The tuner is pretty confident that the straight gate is just a poorly designed product and leaks too much boost upon cracking the gate open and theres no way to fix it other than going to a poppet valve. He's also confient theres no ignition breakdown or floating valves. The fueling is extremely stable as well. Turbo speed is somewhere around the 109,000rpm area. The spanner in the works for me is that prior to this Borgwarner and StraightGate, the car was tuned on -5 twins at a diferent tuner, and he also had issues controlling the boost with it spiking around the same rpm range, so to me this sounds like the same issue and it can't be anything on the turbo side as this was all changed and I think the behaviour is extremely similar, if not the same. We also removed the mac valve and did a run on wastegate pressure and it still spiked and had the same behaviour. My thoughts on possibilities are: Boost Leak VCT Cam Gear isn't reliably activating consistently - (On this however, we did a run with the VCT disabled and the boost still spiked) Turbosmart BOV is not handling the boost? However this seems unlikely to not be able to handle 20psi. I have a couple of logs that I can't make sense of if anybody knows how to read them and can obtain further logs of other parameters if they are not enough, happy to pay for anyones time. The dyno readout with the power figure is the most recent last week. The other picture is from two weeks prior to that where we couldn't break 400kw (we removed the cat), however the issue of the boost control persisted. @Lithium @Piggaz @burn4005 @GTSBoy @discopotato03 I've tagged those that were quite active in recent pages here, no disrespect to those that know turbos well but I missed tagging. Cheers
