Well just like to say hey, cause its my 1st post here, but i'll get straight to the point. In shortI own a Holden commodore V6, and i was originally going to rebuild the motor and have twin GT30s installed and float aorund the 400rwhp mark.
But i have been thinking quite seriously for a while about installing an RB series motor into the VS.
SO ok here wot I basical know so far. Yes it will fit. The VL K-frame bolts straight into a VS, 2ndly an rb25 and 26 will fit the VL Kframe, so i got that part sorted.
The stuff i want to know is.... wots better and why between the 25 and 26. I know the Rb26 is a far more better engine. but wot I want to know, is it worth the extra 3000 to 4000 for a GTR half cut when i will be wanting to up the power of either RB series motor.
All im wanting to do as far as modding the RB motors are manifolds if needed, turbo/s cams and fuel sytem, depending on price maybe do the whole head.
OK... so wot are your thoughts? and wot advise do you have.
P.S. dont waste ur time replying with any holden bashing coments, cause i dont care for them. :bs!:
thanks guys
https://www.sau.com.au/forums/topic/68626-rb26-conversion-help/
thanks guys
Don't worry. I own a Commodore too. My opinion is go the RB26DETT straight away especially if you are looking at power upgrades as the internals are good for 450kW+. Your biggest problem will be the weight of the Commodore. What are they weighing in at now? Your turbo choice and camspecs will probably lean towards a wider torque curve rather than top end power.
What power are you aiming for?
BTW: I'm in Perth too! :headspin:
thanks for the replies, last time i checked a VS was around 1450kg stock. not uch weight has been added. But the Ecotech V6 is about 170kgs whicch is bloody heavy, so by pulling out the v6 and putting in the rb26 and gona get some weight back. But tell me if im wrong, but dont r33 float around the 1400kg mark?
Yeah, dont really want to go the RB30, they have been done to the death with commodores, great motor but i want something i little different thats where an rb26 comes in handy.
Power level, well i was going to be rebuilding the motor with a 4.2Lstroker, forgies... blah blah blah. was aiming for a very doable 450rwhp+ A guy over in queensland with a very close setup to wot i was going to get is pulling 560rwhp at 21psi and getting a 10.5 1/4. I was originally going for low 10s.
Now im looking at an RB26 im not so much eager for 10s, i'd be very happy with with close to 400kw, but im not sure wot u have to do to get to the 400kw mark... power not so important because i dont know wot power levels = a good 1/4, but if i was in the low 12s Id be very happy man. even more happier to shit on some V8s. even the odd skyline :D
I think you will find that the Ecotec is a lot lighter than the GTR engine especially when you take into account turbo's etc... You can get 400kW to 450kW easily out of the engine. You need to look at some bigger turbos and bigger injectors as well as all the rest of the normal exhaust mods. Cams may be needed to keep the torque curve fat but turbo choice will have a lot to do with that. And of course a retune or Power FC should do the trick.
After thinking about. Your Commodre weighs the same as a GTR so expect similar responsiveness. Unfortunately 12sec in a GTR does only require 300kW but that is 4WD. You will have to work on the suspension of your Commodore to go anywhere close to matching the GTR's responsiveness. An extra 50kW should cover it.
The big advantage of this engine choice as opposed to a V8 is that you won't have so much of a problem getting the power to the ground as the torque curve will be a little more spread out. Whilst the V8 boy's will be slipping you will be well on your way.
Yeah I suppose your right, was'nt really think about have two turbos, but at the same Time i did expect the weight of the vs to increase alot if i was going to keep the v6 with twin turbo. Yeah u pretty much have the suspension figured out, King springs, koni, getting it done after the engine and body kit goes on so we can get the right ride height. plus slicks at the drags.
wot do u guys think it is worth buying off the self parts for turbos and manifolds to fuel system and the sort to get the rb26 up to 400kw?
wot do u guys think it is worth buying off the self parts for turbos and manifolds to fuel system and the sort to get the rb26 up to 400kw? And how much?
Most of the install work I will do myself while the engine is out, ie, fuel system and turbo work. I'll leave cams up to an expert.
Yes buy off the shelf, or look around the second-handers for decent turbos. Do your homework on the turbos though. You can pick your cams out as well, just look for relevant articles on cam specs, even brochures. Cam gears you can probably fit yourself if you know what you are doing. Don't worry about custom manifolds as the standards are fine if you are aiming at 400kW. The engine really is ready to be pushed already.
Should be an interesting project.
As far as turbos go you will need something like: GT2530's up to 2540's or equivilant. 2530's will probably be your best bet to make the torque curve fat. Upgrade to some 500+ injectors and that wil give you plenty of room for movement. Not sure, but I think a pump upgrade might be required as well. Tomei cams are good for torque but look around at HKS and Trust as well.
There are as much aftermarket choices with the Skylines as there is with your Commodore engine so just do the same and hunt around the shops and internet sites for what is out there and prices. The import videos are good as they show what people runat the drags and then show how the car performs on the strip.
Prices. Once you start replacing turbos the price jumps up. Think the same ballpark as putting a supercharger kit on a Commodore V8.
fuel system will be after marker, due to the standard V6 being way out of ballpark, I will be looking at installing the turbos while its out the motor, once motor is installed its of to get a custom dump pipe and exhaust made up. What else would it cost for bigger turbos, apart from the turbos?
Next one is, wot sort of exhaust does a 400kw RB26 need?
defently go the 26, you cant go wrong there.
good luck with the wiring, ive so far spent roughly 20 hours merging rb26 loom with a rb25 loom, so the rb26 will run in a r34 gtt. and that cause they are simular!
i imagine the commodre wiring will be completly differant, so youll need to go with a aftermarket computer etc, unless you know someone who can do custom wiring.
unless the vl turbo wiring plugs into vs.
good luck!
steve
as far as I know u can piggyback both ECUs, leave the VS on inplace to look after the odds and ends, and let the othe ecu look after the motor, yes i do know some, looking at around 400 bucks
i have left myself 24gs to do the v6 twin turbo, so that will go a long long way on a rb26 conversion for wot i want.
rb25; Touqe doesnt worry me, the more the better, HELL FUN.
i was going to get a mountain of tq anyway from the V6 so an upgrade rb26 will be pretty close to the same.
with the comment bad earlier with needing an extra 50kw to match a GTR on the 1/4 would i gain that extra 50kw atw by not having the AWD?
It was more a comment about the superior handling the GTR will have over your car and that you would need an extra 50kW on your's to make up for that. Don't get excited about having extra kW because it is rear wheel only. The amount of loss through the front of a dirive-train on a GTR is minimal especially considering it is part time 4WD and only comes in to prevent loss of traction.
hi, just to throw another option in the ring, a guy who i work with has a commodore ute, i think 98-98 model, has a na 3.0l supra bottom end (apparently quite cheap to get) with the 1jzte?(2.5 l turbo head I), one very large turbo and everything else done to suit, putting out 650 hp at rear wheels.
everything toughened up to suit, he's finding out the hard way, everythings breaking then being upgraded with tougher bits.
not to knock the good ol rb, but i think a 1jzte is about $1500, and a 3L na under a grand from memory.
Stephen
Yeah I had a look at the supra motors, and if i were to use one i'd use the TT version, the problem is im looking at alot more custom work to fit the supra motor, but i have to look alot more into, The RB motor fit alot better due to the VL K-frame, plus i'd prefer the skyline motor.
Stephen
Would be a good choice too. Dare I say a better choice due to the larger capacity. Shame it isn't a simple drop in though. Could always use the RB30DE bottom end with GTR top.
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
    • Hmm. I've gotten pretty good outcomes from talking to them about things that I've had go wrong or ideas for improvement. Have had a lot to say about the R32 FUCAs, and they have sent out some replacement parts for those, gratis, on a couple of occasions. Mind you, I have bought a couple hundreds of $ of replacement rod ends for them too!
